Deepstream skipping frames for inference
I am using deepstream with my own model. I trained my own model for action recognition. The model takes in 5 frames which are meant to be separated by 4 frames. The way I trained the model was by taking a 20-frame sample and feeding the model with the 1st, 5th, 10th, 15th, and 20th frames. So the model takes in 5 frames, but not 5 consecutive ones. I know that I can skip frames using the “interval” parameter. For instance, if I set the “interval” parameter to 4, will deepstream give my model frames [0, 1, 2, 3, 4] then frames [8, 9, 10, 11, 12]?( note that this is not my desired behavior since I don’t want consecutive frames fed into the model). If so, is there any way of feeding my model frames [0, 4, 9, 14, 19] then [24, 29, 34, 39, 44] and so on? Thanks!
• DeepStream Version
• TensorRT Version
