Deepstream smart record feature not working
• Hardware Platform (Jetson / GPU) : GPU
• DeepStream Version. : 7.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) :
• Issue Type( questions, new requirements, bugs) : bug
I am running nvida deepstream with an camera RTSP, I am trying to use the deepstream smart record feature, I have configured this as per the docuemntation. when I am running this, I am geeting below error:
root@Server1:/opt/nvidia/deepstream/deepstream-7.0/dumpster/config# deepstream-test5-app -c main_infer_peoplenet_gpu1_smart_record_teju.txt
Civetweb version: v1.16
Server running at port: 9005
nvmultiurisrcbin ERROR from element dsnvurisrcbin0: Invalid path specified for smart-rec-dir-path
** ERROR: <main:1539>: Failed to set pipeline to PAUSED
Quitting
ERROR from dsnvurisrcbin0: Invalid path specified for smart-rec-dir-path
Debug info: gstdsnvurisrcbin.cpp(2073): populate_rtsp_bin (): /GstPipeline:pipeline/GstBin:multiuri_src_bin/GstDsNvMultiUriBin:src_nvmultiurisrcbin/GstBin:src_nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin0
App run failed
Below is my main config file her for reference:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
# Sources
[source-list]
num-source-bins=1
list=rtsp://admin:Abc!2345@4.4.47.182:17554/onvif-media/media.amp?profile=profile_1_h264&sessiontimeout=60&streamtype=unicast
sensor-id-list=ffmpeg_test_cam1
sensor-name-list=ffmpeg_test_cam1
use-nvmultiurisrcbin=1
stream-name-display=1
max-batch-size=1
http-ip=localhost
http-port=9005
[source-attr-all]
enable=1
type=4
num-sources=1
gpu-id=1
cudadec-memtype=1
latency=100
rtsp-reconnect-interval-sec=10
rtsp-reconnect-attempts=-1
select-rtp-protocol=0
udp-buffer-size=2000000
smart-record=2
smart-rec-dir-path=/opt/nvidia/deepstream/deepstream-7.0/dumpster/config/data/smart_recordings/
smart-rec-file-prefix=cam1
smart-rec-cache=20
smart-rec-container=0
smart-rec-start-time=5
smart-rec-default-duration=10
smart-rec-duration=10
smart-rec-interval=10
[sink0]
enable=1
type=1
sync=1
source-id=0
gpu-id=1
nvbuf-memory-type=1
[sink1]
enable=0
type=6
msg-conv-config=dstest5_msgconv_sample_config.yml
msg-conv-payload-type=1
msg-conv-msg2p-new-api=1
msg-conv-frame-interval=1
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so
msg-broker-conn-str=localhost;9092;dumpster_topic_people
[sink2]
enable=0
type=3
container=1
codec=1
sync=1
bitrate=2000000
output-file=/opt/nvidia/deepstream/deepstream-7.0/dumpster/config/data/smart_recordings/out_test_dumpster.mp4
source-id=0
[osd]
enable=1
gpu-id=1
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=1
[streammux]
gpu-id=1
live-source=0
batch-size=1
batched-push-timeout=40000
width=960
height=544
enable-padding=1
nvbuf-memory-type=1
attach-sys-ts-as-ntp=1
drop-pipeline-eos=1
[primary-gie]
enable=1
gpu-id=1
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
interval=0
nvbuf-memory-type=1
config-file=pgie_peoplenet_tao_config_gpu1.txt
[tracker]
enable=0
tracker-width=960
tracker-height=544
gpu-id=1
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
ll-config-file=/opt/nvidia/deepstream/deepstream-7.0/samples/configs/deepstream-app/config_tracker_NvSORT.yml
display-tracking-id=1
[tests]
file-loop=0
I tried changing the paths also for smart record, but it didnt worked.
Is there any reference config file available for enabling deesptream smart record feature.
thanks.
I am checking. will get back to you ASAP.
Here is a workaround. In set_properties_nvuribin of \opt\nvidia\deepstream\deepstream\sources\apps\apps-common\src\deepstream_source_bin.c, add the following code by referring to add “smart-record”.
  if (config->dir_path)
    g_object_set (element_, "smart-rec-dir-path", config->dir_path, NULL);
then rebuild test5.
Thanks for the reply, I tried this, made the code change and rebuilt test5, Also I had to change to simple source with all the attributes under the source group rader bifurcated.
Now this is working as expected.
