Xavier AGX (also tested on Orin) • DeepStream Version
6.0 • JetPack Version (valid for Jetson only)
4.6.3 • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs)
I’ve modified the facial landmark app included in the deepstream_tao_apps repository to use an nvarguscamerasrc. The incoming stream is video/x-raw(memory:NVMM), 1080p, NV12 format, and 30fps.
I’ve set the nvstreammux batch size to 1, live-source is 1, and it’s resolution matches the sources.
I haven’t tweaked anything else in the application. All the probe functions stay the same and I tried rendering the result to the display (This rendering has extremely poor performance (0.3 - 1 fps) but ultimately changed it to nvrtspoutsinkbin and render it on another desktop system where I get a framerate that matches the console output.
What I notice is I get ~24fps when only 1 face is present in the screen, and then it rapidly degrades as you increase the number of faces. So 2 faces = ~12fps, 4 faces = ~6fps, etc. After some reading I saw that I could increase the batch-size of the secondary inference plugin to handle the average number of detections in each frame but this didn’t change the performance. There is also a lot of latency between what the pipeline renders and what the console outputs. Example: I will bring a picture of 3 faces into the frame and the console won’t update the Face Count print statement for ~2 seconds.
I’m not sure why I’m getting such poor performance out of this pipeline. Looking online NVIDIA has evaluated the FaceDetect model to run at 537 fps and FPENet: Facial Landmark Estimator at 1015 fps. That’s a lot of headroom!
CPU for the pipeline stays consistent at 77.2%, then the GPU is always jumping around a lot. However, I did notice, with 1 face it hovers between 45% - 91% with an average of about 70%. When 4 faces are present the GPU util jumps between 6% - 78% with an average around 28%. Is there a better way of measuring GPU util? Ideally I’d like a stable GPU util.
The graph isn’t super descriptive but it shows how each element is taking about 100ms of processing time. For instance: vflip is just nvvideoconvert flip-method=4 and it’s processing range takes between 40ms - 160ms!!
If I run just a simple pipeline: nvarguscamerasrc ! "video/x-raw(memory:NVMM), width=1920, height=1080, format=NV12, framerate=30/1" ! nvvideoconvert flip-method=4 ! nv3dsink
even this nvvideoconvert takes between 15ms - 40ms. I would think this is a seemingly simple operation.
Here’s the latency measurement output of the faciallandmarks pipeline adapted to use nvarguscamerasrc as an input. The input stream is 1080p 30fps. I’ve removed nvtiler.
I just ran the same 4-face video through the deepstream-faciallandmark-app on an new Orin with Jetpack5.0.1 and deepstream 6.1 and got an average fps of 25.10. Obviously better than my Xaviers but still lower than your Xavier performance.
