deepstream-test3 failure
Executing ./deepstream-test3-app dstest3_config.yml (default values) results in failure.
Environment
| NVIDIA-SMI 520.61.05 Driver Version: 520.61.05 CUDA Version: 11.8 |
| | | MIG M. |
| 0 NVIDIA A10 On | 00000000:3B:00.0 Off | 0 |
| 0% 33C P8 20W / 150W | 4MiB / 23028MiB | 0% Default |
| | | N/A |
| 1 NVIDIA A2 On | 00000000:5E:00.0 Off | 0 |
| 0% 33C P8 7W / 60W | 4MiB / 15356MiB | 0% Default |
| | | N/A |
| 2 NVIDIA A30 On | 00000000:AF:00.0 Off | 0 |
| N/A 28C P0 25W / 165W | 4MiB / 24576MiB | 0% Default |
| | | Disabled |
| 3 Tesla T4 On | 00000000:D8:00.0 Off | 0 |
| N/A 35C P8 15W / 70W | 6MiB / 15360MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
Relevant Files
Output:
root@9bcc249ef6c5:/opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/deepstream-test3# ./deepstream-test3-app dstest3_config.yml
Now playing : file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
Using file: dstest3_config.yml
0:00:02.236230880 8845 0x563bc55894d0 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.336996975 8845 0x563bc55894d0 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:02.339678358 8845 0x563bc55894d0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstest3_pgie_config.yml sucessfully
Decodebin child added: source
(deepstream-test3-app:8845): GLib-GObject-WARNING **: 08:38:05.141: g_object_set_is_valid_property: object class 'GstFileSrc' has no property named 'drop-on-latency'
Decodebin child added: decodebin0
Running...
Decodebin child added: qtdemux0
Decodebin child added: multiqueue0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: aacparse0
Decodebin child added: avdec_aac0
Decodebin child added: nvv4l2decoder0
Frame Number = 0 Number of objects = 14 Vehicle Count = 8 Person Count = 6
Frame Number = 1 Number of objects = 12 Vehicle Count = 7 Person Count = 5
Frame Number = 2 Number of objects = 13 Vehicle Count = 7 Person Count = 6
Frame Number = 3 Number of objects = 12 Vehicle Count = 7 Person Count = 5
Frame Number = 4 Number of objects = 14 Vehicle Count = 7 Person Count = 7
Frame Number = 5 Number of objects = 14 Vehicle Count = 8 Person Count = 6
Frame Number = 6 Number of objects = 10 Vehicle Count = 6 Person Count = 4
Frame Number = 7 Number of objects = 13 Vehicle Count = 9 Person Count = 4
0:00:02.549556973 8845 0x563bc442d760 WARN nvinfer gstnvinfer.cpp:2300:gst_nvinfer_output_loop:<primary-nvinference-engine> error: Internal data stream error.
0:00:02.549583580 8845 0x563bc442d760 WARN nvinfer gstnvinfer.cpp:2300:gst_nvinfer_output_loop:<primary-nvinference-engine> error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(2300): gst_nvinfer_output_loop (): /GstPipeline:dstest3-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Frame Number = 8 Number of objects = 11 Vehicle Count = 6 Person Count = 5
Frame Number = 9 Number of objects = 10 Vehicle Count = 6 Person Count = 4
Frame Number = 10 Number of objects = 11 Vehicle Count = 6 Person Count = 5
Deleting pipeline
Steps To Reproduce
- Compiled
cd /opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/deepstream-test3
CUDA_VER=11.7 make
- Executed
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
