Deepstream test1 python app cannot detect decoder
• Hardware Platform (Jetson / GPU) H100
• DeepStream Version 6.4
• TensorRT Version 8.6
• NVIDIA GPU Driver Version (valid for GPU only) 535
Hi, currently i have tested on my local PC on the deepstream6.4 sample python app(test1) with RTX3050, and it is working fine. However, in my H100 pc prompts the below error when i run the same application:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /home/itmax/deepstream_python_apps/apps/MiConv.com__crowd_ind.h264
Adding elements to Pipeline
Linking elements in the Pipeline
/home/itmax/deepstream_python_apps/apps/deepstream-test1/deepstream_test_1.py:220: DeprecationWarning: Gst.Element.get_request_pad is deprecated
  sinkpad = streammux.get_request_pad("sink_0")
Starting pipeline
Failed to query video capabilities: Invalid argument
libv4l2: error getting capabilities: Invalid argument
Error: gst-resource-error-quark: Error getting capabilities for device '/dev/nvidia0': It isn't a v4l2 driver. Check if it is a v4l1 driver. (13): v4l2_calls.c(99): gst_v4l2_get_capabilities (): /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder:
system error: Invalid argument
Command line that i used is:
python3 deepstream_test_1.py video.h264
Any advice to solve this?
This is an installation issue, try the following command, or use docker directly
sudo /opt/nvidia/deepstream/deepstream/install.sh
Thanks, it solved the issue.
