Deepstream_test1_rtsp_in_rtsp_out example not streaming
I am trying to run the example for python deepstream for the rtsp input output.
I produce an input stream on the same device (Orin AGX 64 Gb) with nvstreamer, which is at
rtsp://localhost:31554/nvstream/root/store/nvstreamer_videos/1_ann.mov
and I am expecting an output stream at
rtsp://localhost:8554/ds-test
but I am not getting any.
import cv2
stream = "rtsp://localhost:31554/nvstream/root/store/nvstreamer_videos/1_ann.mov"
#stream = "rtsp://localhost:8554/ds-test"
vcap = cv2.VideoCapture(stream)
while(vcap.isOpened()):
    ret, frame = vcap.read()
    cv2.imshow('VIDEO', frame)
    cv2.waitKey(1)
print("no stream at {:}".format(stream))
This simple test confirms that the input stream exists.
running
python3 deepstream_test1_rtsp_in_rtsp_out.py -i rtsp://localhost:31554/nvstream/root/store/nvstreamer_videos/1_ann.mov --rtsp-ts
however does not yield an output stream at rtsp://localhost:8554/ds-test
I can see that pipeline is running, since it outputs frame numbers & RTSP time stamps.
This problem may be related to this file. I use /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 and it works fine.
Please make sure to follow this documentation
https://docs.nvidia.com/moj/nvstreamer/moj-nvstreamer.html
• DeepStream Version
• TensorRT Version
• The pipeline being used
Jetson Orin AGX 64 Gb
Deepstream 6.4
Jetpack 6.0 DP
TensorRT 8.6.2.3
Please share this file, or try the file I mentioned above
I cannot share this particular file, but I think I resolved the issue in a multistream-in multistream-out setting - not in this example, which still doesnt work, but overall - But any .mov file should work.
I still dont quite understand what difference there should be - since I am giving it the h264 encoded RTSP stream, not the actual file as input?
This is not the case, you can refer to the documentation of nvstreamer.
‘Transcode’ option is not yet supported on the Jetson platform. If this option is selected you could see exception/crash issues for NVStreamer. If video file contains the B-frames, User needs to remove B-frames before uploading it to NVStreamer. Otherwise you could see the corruption in the rtsp/webrtc video playback. To remove the B-frames from video file below ffmpeg command can be used:
If you are on Jetson and h264 contains b-frames, then there may be a problem.
