Hi everyone, I am starting to read about DeepStream and I have runned the script example for “ deepstream-test 2 ” on Jetson Nano.
I have tryed to use file and rtsp such as input and i have the same error.
ERROR from element file-source: Resource not found.
Error details: gstfilesrc.c(533): gst_file_src_start (): /GstPipeline:dstest2-pipeline/GstFileSrc:file-source:
No such file “file:/opt/nvidia/deepstream/deepstream-5.0/samples/streams/cars.mp4”
Returned, stopping playback
Deleting pipeline
I have all the links for “model-file”, “proto-file”, etc for the “dstest2_pgie_config.txt”, “dstest2_sgie1_config.txt”, etc files according to Primary and Secondaries paths on Deepstream folder for the samples models.
I am interesting to know the performance for the NVTRACK in order to count the objects.
Thanks a lot !!!
Can you provide platform and software information in following format:
• DeepStream Version
• TensorRT Version
Are you using DeepStream python or DeepStream C/C++?
deepstream-test 2 is open source for both c/C++ and python.
Have you read README file in the folder /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test2(for C/C++)?
It can only accept h264 element stream local file as input.
Hi @Fiona.Chen
• Hardware Platform (Jetson / GPU) Jeston Nano
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
• TensorRT Version 7.1.3
—Yes, I have but I do not understand when it say “It can only accept h264 element stream local file as input.” I have tried with “file:…/xxx.mp4” “rtsp://…”
—I prefer to use Python, I have downloaded the repository and I have write the inks for the files, engine, protox, etc on each config file (dstest2_pgie_config.txt, dstest2_sgie1_config.txt, etc
—My intention is try to understand how the NVTRACKER works for count the objects detected on the scene but not for each frame, I am talking about count the objects which are on the scene since it appears until it disappears but only once.
Thanks @Fiona.Chen , I will take in count the advices, to be honest I am confusing because some texts recommend such as first step run the examples for learn and understand how Deepstream works.
