Deepstream-test2 no l_user
**• Hardware Platform (Jetson / GPU)**Jetson
• DeepStream Version6.0.1
**• JetPack Version (valid for Jetson only)**4.6.2
• TensorRT Version8.2.1.8
Hi, When I was replicating this project in jetpack4.6.2 , I ran into the same problem.
But I find the problem more complicated. Then I tested my idea on deepstream-test2 and found that my l_user didn’t work. You can see this in the code and results in the figure
result
nvds_add_user_meta_to_obj is used to add user meta to objects, obj_meta->obj_user_meta_list should be null if did call nvds_add_user_meta_to_obj. you can add logs in gst-nvinfer to check.
I solved it. It’s my env problem. Thank you very much
