Hi, Hope you all doing well .
Please have a look at this problem.
i have a problem with the classifier not getting the class id for which it will operate.
as I have set the above parameter in secondary-gie
gie-unique-id=2 # this is classifier gie that why it id is 2 and primary gie id is 1
operate-on-gie-id=1 # it mean operate on primary gie which id is 1
operate-on-class-ids=4 # which class of primary gie you want to apply classification so say id 0 or may be other.
I have set the id =4 which in my case is a person but the classifier inference show on the Whole video frame like this.
The code that I used is deepstream-test2.py I just added the following code instead of src_pad_probe.
color_list = {"balcony_with_railing": (0, 0, 1),
"balcony_without_railing": (1, 0.8, 0),
"helmet": (0.6, 0.2, 1),
"incomplete_railing": (1, 0, 0),
"person": (0.2, 0.8, 0.2),
"rail": (0.5, 0.8, 0.5)}
past_tracking_meta=[0]
PGIE_CLASS_ID_balcony_with_railing = 0
PGIE_CLASS_ID_balcony_without_railing = 1
PGIE_CLASS_ID_helmet = 2
PGIE_CLASS_ID_incomplete_railing = 3
PGIE_CLASS_ID_person = 4
PGIE_CLASS_ID_rail = 5
pgie_classes_str= ["balcony_with_railing", "balcony_without_railing", "helmet","incomplete_railing", "person", "rail"]
def pgie_src_pad_buffer_probe(pad,info,u_data):
#Intiallizing object counter with 0.
# obj_counter = {
# PGIE_CLASS_ID_VEHICLE:0,
# PGIE_CLASS_ID_PERSON:0,
# PGIE_CLASS_ID_BICYCLE:0,
# PGIE_CLASS_ID_ROADSIGN:0
field_names = ["Timestamp",'Frame Number', 'Number of Objects', 'Helmet_count',
'Person_count', 'Balcony_with_railing', "Balcony_without_railing","Incomplete_railing","Rail"]
frame_number=0
obj_counter ={
PGIE_CLASS_ID_balcony_with_railing:0,
PGIE_CLASS_ID_balcony_without_railing:0,
PGIE_CLASS_ID_helmet:0,
PGIE_CLASS_ID_incomplete_railing:0,
PGIE_CLASS_ID_person: 0,
PGIE_CLASS_ID_rail: 0,
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number=frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
#---------------------this code is for adding custom label to each class -----------
txt_params = obj_meta.text_params
# Set display_text. Any existing display_text string will be
# freed by the bindings module.
txt_params.display_text = pgie_classes_str[obj_meta.class_id]
obj_counter[obj_meta.class_id] += 1
#-----------------end of code ---------------------------------
#---------------the below code is for setting different color to each class------------------
color = color_list[obj_meta.obj_label.split("\\")[0]]
rect_params = obj_meta.rect_params
rect_params.border_color.set(*color, 1)
try:
l_obj=l_obj.next
break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
# py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Helmet_count={} Person_count={} Balcony_with_railing={} Balcony_without_railing={} Incomplete_railing={} Rail={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_helmet], obj_counter[PGIE_CLASS_ID_person],obj_counter[PGIE_CLASS_ID_balcony_with_railing],
# obj_counter[PGIE_CLASS_ID_balcony_without_railing],obj_counter[PGIE_CLASS_ID_incomplete_railing],obj_counter[PGIE_CLASS_ID_rail])
ct = datetime.datetime.now()
ditcc = {"Timestamp":ct,'Frame Number':frame_number, 'Number of Objects':num_rects, 'Helmet_count':obj_counter[PGIE_CLASS_ID_helmet],
'Person_count':obj_counter[PGIE_CLASS_ID_person], 'Balcony_with_railing':obj_counter[PGIE_CLASS_ID_balcony_with_railing],
"Balcony_without_railing":obj_counter[PGIE_CLASS_ID_balcony_without_railing],
"Incomplete_railing":obj_counter[PGIE_CLASS_ID_incomplete_railing],"Rail":obj_counter[PGIE_CLASS_ID_rail]}
with open('event.csv', 'a') as f_object:
dictwriter_object = DictWriter(f_object, fieldnames=field_names)
dictwriter_object.writerow(ditcc)
f_object.close()
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 12
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 0.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame=l_frame.next
break
