In the example deepstream-test2, the h264 file provided in stream or the yaml file in test2 are directly segfaulted
run sample_720p.h264
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvTrackerParams::getConfigRoot()] !!![WARNING] Can't open config file (/opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-test2/../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml). Will go ahead with default values
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
Thread 1 "deepstream-test" received signal SIGBUS, Bus error.
0x0000ffffe164fca4 in ?? () from /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
(gdb) bt
#0 0x0000ffffe164fca4 in () at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
#1 0x0000ffffe166dec8 in () at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
#2 0x0000ffffe1653550 in () at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
#3 0x0000ffffe164e090 in () at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
#4 0x0000ffffe1672130 in NvMOT_Init () at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
#5 0x0000ffffe4379f34 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so
#6 0x0000ffffe437a124 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so
#7 0x0000ffffe43855cc in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so
#8 0x0000ffffefc9ba44 in gst_base_transform_activate (trans=trans@entry=0xaaaaab5fe190, active=active@entry=1) at gstbasetransform.c:2399
#9 0x0000ffffefc9bcd0 in gst_base_transform_sink_activate_mode (pad=<optimized out>, mode=GST_PAD_MODE_PUSH, active=1, parent=0xaaaaab5fe190) at gstbasetransform.c:2465
#10 gst_base_transform_sink_activate_mode (pad=<optimized out>, parent=0xaaaaab5fe190, mode=<optimized out>, active=1) at gstbasetransform.c:2454
#11 0x0000fffff7ecbb2c in () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#12 0x0000fffff7ecc310 in gst_pad_set_active () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#13 0x0000fffff7ea0970 in () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#14 0x0000fffff7eb6710 in gst_iterator_fold () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#15 0x0000fffff7ea3f70 in () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#16 0x0000fffff7ea4418 in () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#17 0x0000fffff7ea6ddc in gst_element_change_state () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#18 0x0000fffff7ea751c in () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#19 0x0000fffff7e7d434 in () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#20 0x0000fffff7ea6ddc in gst_element_change_state () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#21 0x0000fffff7ea6e1c in gst_element_change_state () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#22 0x0000fffff7ea751c in () at /lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#23 0x0000aaaaaaaa2e48 in main (argc=2, argv=0xffffffffec58) at deepstream_test2_app.c:525
run dstest2_config.yml
(gdb) set args dstest2_config.yml
(gdb) r
Starting program: /opt/nvidia/deepstream/deepstream-6.2/sources/apps/sample_apps/deepstream-test2/deepstream-test2-app dstest2_config.yml
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/aarch64-linux-gnu/libthread_db.so.1".
With tracker
Program received signal SIGSEGV, Segmentation fault.
0x0000fffff7b62974 in ?? () from /opt/nvidia/deepstream/deepstream-6.2/lib/libnvds_yml_parser.so
(gdb) bt
#0 0x0000fffff7b62974 in () at /opt/nvidia/deepstream/deepstream-6.2/lib/libnvds_yml_parser.so
#1 0x0000fffff7b7b860 in nvds_parse_gie_type () at /opt/nvidia/deepstream/deepstream-6.2/lib/libnvds_yml_parser.so
#2 0x0000aaaaaaaa2534 in main (argc=2, argv=0xffffffffec48) at deepstream_test2_app.c:361
(gdb)
Can you ran any other sample in your environment?
• DeepStream Version
• TensorRT Version
• The pipeline being used
Did you modify some config? Can the other samples run in your Xavier NX?
Deepstream6.2 was verified in JP5.1.1 and by default all samples can run correctly, not sure if some config changed in your setup.
./deepstream-test2-app sample_720p.h264
With tracker
Using file: sample_720p.h264
Opening in BLOCKING MODE
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:16.380483978 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 4]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:16.490211460 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary3-nvinference-engine> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 4]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:16.666185541 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary3-nvinference-engine> [UID 4]: Load new model:dstest2_sgie3_config.txt sucessfully
0:00:18.398442388 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 3]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:18.491311207 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 3]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:18.655553927 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary2-nvinference-engine> [UID 3]: Load new model:dstest2_sgie2_config.txt sucessfully
0:00:20.351048345 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:20.439908661 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:20.607844871 7866 0xaaaad8a7c610 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 2]: Load new model:dstest2_sgie1_config.txt sucessfully
段错误 (核心已转储)
Debugging found that as long as the method similar to nvds is called, it will be directly abnormal. Is it a problem with yaml or where does it need to be initialized?
