Hello, when I used the test program, I configured it to use perf mode. When the program created the nvurisrcbin plugin node in gst_element_factory_make, the node creation failed, and the test program could not execute further. If the node created without using perf mode is uridecodebin, the test program can run. Please tell me how to solve this problem. In addition, this problem may be the same as the failure of adding streams in deepstream-serverhttps://forums.developer.nvidia.com/t/deepstream-server-add-failed-using-add-interface-api-v1-stream-add/294272
Moving to DeepStream forum, and please also provide complete information as applicable to your setup.
• DeepStream Version
• TensorRT Version
• The pipeline being used
Can you get output from the following command line ?
gst-inspect-1.0 nvurisrcbin
If not, try sudo /opt/nvidia/deepstream/deepstream/install.sh
This may be an installation issue
I use sudo/opt/nvidia/deepstream deepstream/install.sh has solved the problem
