When running deepstream-test3, I want to override the gpu-id configs for pgie
and all gstreamer elements that utilize the GPU. On a multi-gpu server, after setting the gpu-id to 1, I noticed that there was still a bit of utilization on gpu-id=0.
Please correct me if I am wrong, but I am assuming that this is occurring because input frame buffer is attached to gpu-id=0. I noticed that this slows down the inference pipeline by 14 seconds when running inference on four 5306 frame videos. Is there a way to make it so that every single operation performed on the GPU placed on the same device (that is not gpu-id=0)?
FYI the use case is as follows:
# --gpu 1 (override gstreamer gpu-id settings from config
# such as pgie / sgie and replace with this value)
python3 deepstream_test_4.py --gpu 1
Gstreamer element gpu-id property is being overriden as follows:
Can you share the sample and config files you used to repro the issue you mentioned?
I have attached the code needed to reproduce the issue. gpu_reproduction.py (15.3 KB). Please place the python script in the same location as deepstream_test_3.py.
FYI: The config file is identical to the one used in deepstream_test_3.py: dstest3_pgie_config.txt
I ran the script with the following configuration:
You can not set gpu-id directly for source_bin. please refer to function decodebin_child_added in sources/apps/apps-common/src/deepstream_source_bin.c for how to set gpu-id for dGPU.
Thank you for the helpful response. I took a look at the function decodebin_child_added and managed to get the problem resolved.
For those who may come across similar use case, I will leave my basic approach below. Feel free to modify to suit your specific design / use case.
def decodebin_child_added(child_proxy,Object,name,user_data):
print("Decodebin child added:", name, "\n")
try:
# feel free to receive gpu id as input variable elsewhere
gpu_id = 1
# set gpu-id if it exists
Object.set_property('gpu-id', gpu_id)
except:
# current Gstreamer element does not have property "gpu-id"
# Feel free to do some logging for debugging purposes
pass
if(name.find("decodebin") != -1):
Object.connect("child-added",decodebin_child_added,user_data)
