# Deepstream test3 with tracker
**URL:** <https://forums.developer.nvidia.com/t/deepstream-test3-with-tracker/183403>\
**Category:** DeepStream SDK\
**Created:** [July 12, 2021, 11:06am UTC](https://forums.developer.nvidia.com/t/deepstream-test3-with-tracker/183403 "2021-07-12T11:06:52Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![dilip.s](https://developer.download.nvidia.com/images/forums/profile-default-devtalk-84.png) [@dilip.s](https://forums.developer.nvidia.com/u/dilip.s)\
**Post date:** [July 12, 2021, 5:25pm UTC](https://forums.developer.nvidia.com/t/deepstream-test3-with-tracker/183403/2 "2021-07-12T17:25:24Z")
</div>
I don’t have a solution to your problem but I came across this discussion which seemed relevant to the issue you are trying to solve:
> [@NvdsTracker API sample](https://forums.developer.nvidia.com/t/nvdstracker-api-sample/79757/11):
> I was facing the same issue with object-id, the mistake i made was i added the probe in source pad of nvinfer element. But object-id is set by nvtracker element so i should add the probe in source pad of nvtracker or other elements that are downstream to nvtracker. you can resolve it by changing this code infer\_src\_pad = gst\_element\_get\_static\_pad (pgie, "src"); if (!infer\_src\_pad) g\_print ("Unable to get source pad\n"); else gst\_pad\_add\_probe (infer\_src\_pad, GST\_PAD\_PROBE\_TYPE\_BUF…
Thanks,
Dilip.
_[View the full topic](https://forums.developer.nvidia.com/t/deepstream-test3-with-tracker/183403)._
