• Hardware Platform (Jetson / GPU) jetson xavier nx
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5.1
• TensorRT Version 7.1.3
• Issue Type( questions, new requirements, bugs) questions
All console messages are good by running the following commands, but nothing was received from rabitmq:
export GST_DEBUG_FILE=debug.txt
export GST_DEBUG=4
./deepstream-test4-app -i /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_amqp_proto.so --conn-str="localhost;5672;guest;guest" --cfg-file=cfg_amqp.txt --no-display
cfg_amqp.txt (1.4 KB)
console.txt (76.8 KB)
debug.txt (165.9 KB)
The workable sender and receiver samples are:
amqp_recv.py (697 Bytes)
amqp_send.py (381 Bytes)
How to publish messages to amqp?
