Deepstream Transfer Learning App - Black images when running on second GPU
GPU - RTX A5000 x 2
• DeepStream Version
6.1 via docker image nvcr.io/nvidia/deepstream:6.1-devel
N/A
• TensorRT Version
| NVIDIA-SMI 510.73.05    Driver Version: 510.73.05    CUDA Version: 11.6     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA RTX A5000    Off  | 00000000:01:00.0 Off |                  Off |
| 47%   75C    P2   196W / 230W |   4031MiB / 24564MiB |     72%      Default |
|                               |                      |                  N/A |
|   1  NVIDIA RTX A5000    Off  | 00000000:02:00.0 Off |                  Off |
| 30%   31C    P8    12W / 230W |      8MiB / 24564MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
Bug?
I want to run the Transfer Learning App on two GPUs at the same time. I have two RTX A5000 cards. I can successfully run it on GPU 0 but when I try to run it on GPU 1 it runs, however it saves black images.
Steps to reproduce:
Good run on GPU 0:
# Run the docker:
docker run \
--gpus all \
-it \
--rm \
--net=host \
--privileged \
-v /tmp/.X11-unix:/tmp/.X11-unix \
-v $(pwd):/code/ \
-e DISPLAY=$DISPLAY \
-w /opt/nvidia/deepstream/deepstream-6.1/sources/apps/sample_apps/deepstream-transfer-learning-app/configs \
# Create the output directory
mkdir output
# Run the example
deepstream-transfer-learning-app -c ds_transfer_learning_app_example.txt
# View an output image - SUCCESS!
apt install -y feh
feh output/images/camera-0_2022-06-06T09\:47\:55+0000_0000000044.jpg
Now try to run it on GPU1 instead:
# Remove traces of last run
rm -r output && mkdir output
# Change the app config file for GPU1
sed -i 's/gpu-id=0/gpu-id=1/g' ds_transfer_learning_app_example.txt
sed -i 's/gpu0/gpu1/g' ds_transfer_learning_app_example.txt
# Change the PGIE to GPU1
sed -i 's/gpu-id=0/gpu-id=1/g' config_infer_primary_ds_transfer_learning.txt
sed -i 's/gpu0/gpu1/g' config_infer_primary_ds_transfer_learning.txt
# Run again
# View an output image - FAIL - it's black!
feh camera-0_2022-06-06T10:03:46+0000_0000000042.jpg
Note that I also have set the output sink to “FakeSink” (type=1):
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=1
source-id=0
gpu-id=1
nvbuf-memory-type=0
Am I missing some configuration? Or is this a bug?
OK, after a bit of digging I found this: Deeepstream-test5 error when save image - #33 by hung
If I run my app with the CUDA_VISIBLE_DEVICES=1, e.g:
CUDA_VISIBLE_DEVICES=1 deepstream-transfer-learning-app -c ds_transfer_learning_app_example.txt
Then it works. Note that you must still use gpu-id=0 in your configuration files.
Note that there is a typo in the linked thread, e.g.
CUDA_VISIBLE_DEVICES=1  # Correct
CUDA_VISIABLE_DEVICES=1 # Wrong! Typo
It would still be good to have the bug confirmed and fixed however.
The issue reproduced, we are investigating the issue. thanks for reporting the issue.
The fix will be in upcoming release.
