DeepStream video analysis demo chart v0.1.19 Failed to connect
L4
• DeepStream Version
DeepStream helm chart doc v0.1.9
https://catalog.ngc.nvidia.com/orgs/nvidia/helm-charts/video-analytics-demo?version=0.1.9
• TensorRT Version
I followed the documentation to deploy the chart on a 3-node Kubernetes cluster with an L4 GPU. The deployment steps are listed below.
I would like to ask DeepStream experts for advice or suggestions on how to resolve the issue where the demo video cannot be played. Any feedback would be greatly appreciated. Thank you.
Issue1: visit demo UI url, no stream/video show up
$ echo http://$NODE_IP:$ANT_NODE_PORT
http://172.27.119.46:31115
Issue2: logs with error and warning
$ kubectl logs nvdsdemo-video-analytics-demo-6488777549-t6z5m
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
ERROR from src_elem0: Could not open resource for reading and writing.
Debug info: gstrtspsrc.c(7893): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstRTSPSrc:src_elem0:
Failed to connect. (Generic error)
(deepstream-app:1352): GLib-GObject-WARNING **: 02:38:17.280: g_object_get_is_valid_property: object class ‘GstUDPSrc’ has no property named ‘pt’
Deploy the chart
Deployment steps:
  1. Download chart
    helm fetch https://helm.ngc.nvidia.com/nvidia/charts/video-analytics-demo-0.1.9.tgz
  2. update the values.yaml
cameras:
camera1: rtsp://172.27.112.82:8554/taipei
$ kubectl get po -o wide
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
nvdsdemo-video-analytics-demo-6488777549-t6z5m 1/1 Running 0 20h 10.42.1.88 ks-9296674
nvdsdemo-video-analytics-demo-webui-78b68db55b-nqvn8 2/2 Running 0 20h 10.42.2.54 ks-9292828
run “nvidia-smi -l” command in the 1st pod
Tue Mar 17 02:54:34 2026
| NVIDIA-SMI 580.82.09 Driver Version: 580.82.09 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA L4 Off | 00000000:C1:00.0 Off | 0 |
| N/A 48C P0 28W / 72W | 362MiB / 23034MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1352 C deepstream-app 354MiB |
ps: It’s no problem to view the camera1 steaming using VLC
  1. This is a legacy chart base on DS-6.2. If you want to deploy it by helm, try to override these two files.
    I update it to DS-8.0.
    deployment.yaml (7.3 KB)
    values.yaml (2.3 KB)
After the service starts, you can open this url in browser to check results . http://host_ip:31115
Like this:
2.You also can try it through deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display.txt. This is the backend implementation of the service.
3.Additionally, ensure that the IP address is accessible within the Pod; 172.xx.xx.xxx may not be accessible within the container. You can try publishing the stream to the host IP address.
Thank you for the prompt reply. I will try deploying again using the attached deployment.yaml and values.yaml and will update the results afterward.
It has been identified that the issue was caused by the video analytics pod not being able to access the IP camera. It is now working properly. Thank you for the guidance.
By the way, are there any recommended metrics to measure the performance of the streaming analytics? For example, latency, accuracy, number of streams, GPU utilization, GPU temperature, etc. Any insights would be greatly appreciated.
You can refer to these two FAQs to obtain the pipeline’s FPS/latency.
Since your current application uses deepstream-app as the backend, this should be fairly easy to implement. However, I recommend using local files for testing, as network streaming may cause gaps in latency/fps testing due to delays.
This data can be monitored through nvidia-smi
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
