DeepStream video analysis demo chart v0.1.19 using mp4 files instead of camera rtsp
L40
• DeepStream Version
DeepStream helm chart doc v0.1.9
https://catalog.ngc.nvidia.com/orgs/nvidia/helm-charts/video-analytics-demo?version=0.1.9
• TensorRT Version
I followed the documentation to deploy the chart on a 3-node Kubernetes cluster with an L40 GPU:
helm install dsdemo video-analytics-demo
–set “cameras.camera1=rtsp://172.24.114.122:8554/cam1”
–set resources.limits.“nvidia.com/gpu”=2
–set resources.limits.cpu=32
–set resources.limits.memory=64Gi
–set resources.requests.“nvidia.com/gpu”=2
–set resources.requests.cpu=16
–set resources.requests.memory=32Gi
I would like to ask DeepStream experts for advice or suggestions on how to resolve the issue where the demo video often lag and fuzzy. Any feedback would be greatly appreciated. Thank you.
Issue1: using mp4 files instead of rtsp://xxx:8554/cam1
–set “cameras.camera1=/mnt/taipei1.mp4”
(/mnt/ is mounted to the pod)
Issue2: how to improve rtsp://xxx:8554/cam1 steaming quality
I use mediamtx-ffmpeg to play the .mp4 file as the streaming source
rtspTransports: [“tcp”]
paths:
cam1:
source: publisher
runOnInit: >
ffmpeg
-re -stream_loop -1 -thread_queue_size 1024
-i /mnt/airport1.mp4
-c copy
-rtsp_transport tcp
-reset_timestamps 1
-avoid_negative_ts make_zero
-rtpflags latm
-f rtsp
rtsp://localhost:$RTSP_PORT/$MTX_PATH?pkt_size=1200
runOnInitRestart: yes
cam2:
Hi, which Jetson platform you are using?
thanks for reply, I just follow the chart doc (v0.1.9) and deploy chart to a 3-node kubernetes cluster (not sure what Jetson used?)
Looking forward to any feedback from DeepStream experts, thank you.
The helm chart you mentioned is too old to be maintained. It is based on DeepStream 6.0 and now DeepStream 9.0 is the latest version.
What is your user scenario? Is it possible to use DeepStream sample apps directly in your device?
We are helm chart user, look forward to have DS 9.0 chart, thanks.
Can you tell us which company and what kind of product you are working for?
This is Robert from Infortrend, Edge AI for physical security.
The helm chart is not supported by DeepStream 9.0 now.
