• Hardware Platform (GPU) GeForce MX250
• DeepStream Version 6.2
• TensorRT Version 8.6.1.6-1+cuda12.0
• NVIDIA GPU Driver Version (valid for GPU only) 535.104.12
docker run -it --rm --net=host --gpus all -e DISPLAY=$DISPLAY --device /dev/snd -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream:6.2-triton nvcr.io/nvidia/deepstream
deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
libEGL warning: MESA-LOADER: failed to retrieve device information
libEGL warning: DRI2: could not open /dev/dri/card0 (No such file or directory)
0:00:02.038675086 1031 0x55bc4caf1e60 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.050087314 1031 0x55bc4caf1e60 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:02.053382271 1031 0x55bc4caf1e60 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:239>: Pipeline ready
WARNING from src_elem: No decoder available for type ‘audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2’.
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin6/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin5/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin4/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin8/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin10/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin9/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin11/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin13/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin12/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin14/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin15/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin16/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin17/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin18/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin19/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin20/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin22/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin23/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin21/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin24/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin26/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin25/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin27/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin29/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin28/GstURIDecodeBin:src_elem
Error String : Feature not supported on this GPUError Code : 801
ERROR from nvv4l2decoder5: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin6/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin6/nvv4l2decoder:nvv4l2decoder5:
Maybe be due to not enough memory or failing driver
ERROR from qtdemux6: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin6/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin6/GstQTDemux:qtdemux6:
streaming stopped, reason error (-5)
ERROR from multiqueue5: Internal data stream error.
Debug info: gstmultiqueue.c(2357): gst_multi_queue_sink_event (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin6/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin6/GstMultiQueue:multiqueue5:
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
nvstreammux: Successfully handled EOS for source_id=4
nvstreammux: Successfully handled EOS for source_id=5
nvstreammux: Successfully handled EOS for source_id=6
nvstreammux: Successfully handled EOS for source_id=7
nvstreammux: Successfully handled EOS for source_id=8
nvstreammux: Successfully handled EOS for source_id=9
nvstreammux: Successfully handled EOS for source_id=10
nvstreammux: Successfully handled EOS for source_id=11
nvstreammux: Successfully handled EOS for source_id=12
nvstreammux: Successfully handled EOS for source_id=13
nvstreammux: Successfully handled EOS for source_id=14
nvstreammux: Successfully handled EOS for source_id=15
nvstreammux: Successfully handled EOS for source_id=16
nvstreammux: Successfully handled EOS for source_id=17
nvstreammux: Successfully handled EOS for source_id=18
nvstreammux: Successfully handled EOS for source_id=19
nvstreammux: Successfully handled EOS for source_id=20
nvstreammux: Successfully handled EOS for source_id=21
nvstreammux: Successfully handled EOS for source_id=22
nvstreammux: Successfully handled EOS for source_id=23
nvstreammux: Successfully handled EOS for source_id=24
nvstreammux: Successfully handled EOS for source_id=25
nvstreammux: Successfully handled EOS for source_id=26
nvstreammux: Successfully handled EOS for source_id=27
nvstreammux: Successfully handled EOS for source_id=28
nvstreammux: Successfully handled EOS for source_id=29
ERROR from nvv4l2decoder8: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin8/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin8/nvv4l2decoder:nvv4l2decoder8:
ERROR from qtdemux8: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin8/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin8/GstQTDemux:qtdemux8:
ERROR from nvv4l2decoder6: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin4/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin4/nvv4l2decoder:nvv4l2decoder6:
ERROR from qtdemux4: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin4/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin4/GstQTDemux:qtdemux4:
ERROR from nvv4l2decoder14: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin14/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin14/nvv4l2decoder:nvv4l2decoder14:
ERROR from qtdemux14: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin14/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin14/GstQTDemux:qtdemux14:
ERROR from nvv4l2decoder9: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin10/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin10/nvv4l2decoder:nvv4l2decoder9:
ERROR from qtdemux10: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin10/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin10/GstQTDemux:qtdemux10:
ERROR from nvv4l2decoder2: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin2/nvv4l2decoder:nvv4l2decoder2:
ERROR from qtdemux1: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin2/GstQTDemux:qtdemux1:
ERROR from nvv4l2decoder11: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin11/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin11/nvv4l2decoder:nvv4l2decoder11:
ERROR from qtdemux11: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin11/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin11/GstQTDemux:qtdemux11:
ERROR from nvv4l2decoder13: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin12/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin12/nvv4l2decoder:nvv4l2decoder13:
ERROR from qtdemux12: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin12/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin12/GstQTDemux:qtdemux12:
ERROR from nvv4l2decoder4: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder4:
ERROR from qtdemux5: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux5:
ERROR from nvv4l2decoder3: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3/nvv4l2decoder:nvv4l2decoder3:
ERROR from qtdemux2: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3/GstQTDemux:qtdemux2:
ERROR from nvv4l2decoder12: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin13/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin13/nvv4l2decoder:nvv4l2decoder12:
ERROR from qtdemux13: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin13/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin13/GstQTDemux:qtdemux13:
ERROR from nvv4l2decoder21: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin22/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin22/nvv4l2decoder:nvv4l2decoder21:
ERROR from qtdemux22: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin22/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin22/GstQTDemux:qtdemux22:
ERROR from nvv4l2decoder0: Failed to process frame.
Debug info: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin5/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin5/nvv4l2decoder:nvv4l2decoder0:
ERROR from qtdemux0: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin5/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin5/GstQTDemux:qtdemux0:
App run failed
When i run this in docker i get a small window which is black and output is not displayed
