Hello, I am attempting to use DeepStream with a model that has dynamic outputs( sizes [-1,4], [-1], and [-1]). I tried to start DeepStream but received errors which apparently are due to the -1 in the output shape. I have been able to successfully host this model on a triton server, but have not been able to find much documentation for using DeepStream with Triton. What would be the recommended method here? If it is DeepStream with Triton, would you mind providing links to documentation that I can use for setting up those config files?
Sent you the ONNX model through direct message. I will review that documentation, thank you. Note the ONNX shape appears as 0 instead of -1, but when converting with trtexec and using the plan file it ends up being -1.
These correspond to conf scores and class numbers, so sadly I cannot remove them. The standard output is the bbox coordinates. This is a object detection (FasterRCNN) model. Is there any other solution?
The first dimension of both 2621 and 2622 is dynamic as well. Did you mean only the batch dimension can be dynamic? As for 2621 and 2622 it is the number of detections that controls their dynamic dimension.
