So the Warning is gone but the cuda issue is back.
Immediately after installing the system with DS7 via SDK Manager it looks like it has not completed the installation. I have to install firefox to get browser. Strange behavior compared to previous releases.
- SDK Manager install completes
- Installing dependencies, but change Python3.8-dev to 3.10-dev
- Install PYDS for 1.1.11 version with the whl.
- sudo git clone GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications -b v1.1.11
to: /opt/nvidia/deepstream/deepstream-7.0/sources
Then ran the …/apps/deepstream-test1/deepstream_test1.py.
This produces the same error.
I then installed cuda-python on the system.
pip3 install cuda-python
This did not do the trick. Uninstalled it with
pip3 uninstall cuda-python
Then removed deepstream_python_apps from /opt…/sources
Git cloned the latest to /opt/…
sudo git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
Started the application and it produced a lot of Warnings and had to convert to int8 etc but after a while it did start.
I don’t know why this works or if something is not ok. But I will have to install torch and torchvision too.
I will reinstall now again from scratch and go with the latest deepstream-python-apps from the start and not
specify the version with -b x.x.x. Lets see. Keep you posted.
For torch I will use 2.1.0
https://nvidia.box.com/shared/static/0h6tk4msrl9xz3evft9t0mpwwwkw7a32.whl
For torchvision v0.16.1
git clone --branch <version> https://github.com/pytorch/vision torchvision # see below for version of torchvision to download
$ cd torchvision
$ export BUILD_VERSION=0.x.0 # where 0.x.0 is the torchvision version
$ python3 setup.py install --user
