cktay
1
I evaluate the performance of deep stream 2.0 with sample mp4
I have tested same primary detector renet10 for 3 streams and 30 streams
I notice enable/ disable tiled display plugin may result different fps performance
3 stream (tiled display=enable) : 310fps per stream
3 stream (tiled display=disable) : 30fps per stream
May i know which indicates the correct performance ?
Hi cktay,
Could you share your config file?
30fps: looks some plugin run at 30 fps when tilted display=disable.
wayne zhu
cktay
3
Thanks for reply,
Below are the config file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
flow-original-resolution=1
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=5
columns=6
width=1280
height=720
gpu-id=1
[source0]
enable=0
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://../../streams/sample_1080p.mp4
num-sources=2
gpu-id=0
[source1]
enable=0
type=3
uri=file://../../streams/sample_720p.h264
num-sources=2
gpu-id=0
[source2]
enable=1
type=3
uri=file://../../streams/sample_720p.mp4
num-sources=30
gpu-id=1
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=1
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
[osd]
enable=1
gpu-id=1
osd-mode=0
border-width=10
text-size=30
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[primary-gie]
enable=1
gpu-id=1
net-scale-factor=0.0039215697906911373
model-file=../../models/Primary_Detector/resnet10.caffemodel
proto-file=../../models/Primary_Detector/resnet10.prototxt
model-cache=../../models/Primary_Detector/resnet10.caffemodel_b30_int8.cache
#Required to display the PGIE labels, should be added even when using config-file
#property
labelfile-path=../../models/Primary_Detector/labels.txt
int8-calib-file=../../models/Primary_Detector/cal_trt4.bin
net-stride=16
batch-size=30
## 0=FP32 and 1=INT8 mode
network-mode=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
num-classes=4
class-thresholds=0.2;0.2;0.1;0.2
class-eps=0.2;0.2;0.2;0.2
class-group-thresholds=1;1;1;1
roi-top-offset=0;0;0;0
roi-bottom-offset=0;0;0;0
detected-min-w=0;0;0;0
detected-min-h=0;0;0;0
detected-max-w=1280;1280;1280;1280
detected-max-h=720;720;720;720
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
parse-func=4
output-bbox-name=conv2d_bbox
output-blob-names=conv2d_cov
parser-bbox-norm=35.0;35.0
#config-file=config_infer_resnet.txt
[tests]
file-loop=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
codec=3
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
You are using mpeg4 video encode?
We don’t have HW acceleration for mpeg4.
THanks
wayne zhu
cktay
5
I was using same sink1 setting for both tiled display enabled and disabled. Different fps yield
I changed to h264 codec in sink1, with tiled display disabled. I get 30fps as well
