Its a HPE Proliant Server and the display is drived by Matrox iGPU.
Yes I tried exporting display, No luck, Thanks Amycao.
Hi AastaLLL, the demsg is as follows, hope it helps in further debugging
[code]ProLiant-DL380-Gen10:~$ dmesg
[ 0.000000] microcode: microcode updated early to revision 0x200004d, date = 2018-05-15
[ 0.000000] Linux version 4.15.0-34-generic (buildd@lgw01-amd64-037) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.10)) #37~16.04.1-Ubuntu SMP Tue Aug 28 10:44:06 UTC 2018 (Ubuntu 4.15.0-34.37~16.04.1-generic 4.15.18)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-34-generic root=UUID=72fc1412-d8a1-4ba8-9458-e4d8d864e7bf ro quiet splash vt.handoff=7
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: ‘MPX bounds registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: ‘MPX CSR’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x020: ‘AVX-512 opmask’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x040: ‘AVX-512 Hi256’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x080: ‘AVX-512 ZMM_Hi256’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: ‘Protection Keys User registers’
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: xstate_offset[5]: 960, xstate_sizes[5]: 64
[ 0.000000] x86/fpu: xstate_offset[6]: 1024, xstate_sizes[6]: 512
[ 0.000000] x86/fpu: xstate_offset[7]: 1536, xstate_sizes[7]: 1024
[ 0.000000] x86/fpu: xstate_offset[9]: 2560, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x2ff, context size is 2568 bytes, using ‘compacted’ format.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000008e000-0x000000000008ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000090000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000865e0fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000865e1000-0x00000000865e3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000865e4000-0x000000008f1e5fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000008f1e6000-0x00000000901fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000090200000-0x0000000090200fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000090201000-0x0000000090215fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000090216000-0x0000000090216fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000090217000-0x0000000090931fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000090932000-0x000000009a131fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000009a132000-0x000000009a531fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000009a532000-0x000000009ad31fff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000009ad32000-0x000000009ae31fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000009ae32000-0x000000009d231fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000009d232000-0x000000009d431fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000009d432000-0x000000009d433fff] usable
[ 0.000000] BIOS-e820: [mem 0x000000009d434000-0x000000009d4b4fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000009d4b5000-0x00000000af7fffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000af800000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe00ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000103fffefff] usable
[ 0.000000] BIOS-e820: [mem 0x000000103ffff000-0x000000103fffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.60 by HPE
[ 0.000000] efi: SMBIOS=0x90219000 SMBIOS 3.0=0x90217000 ACPI=0x9d431000 ACPI 2.0=0x9d431014 MEMATTR=0x94572018
[ 0.000000] secureboot: Secure boot could not be determined (mode 0)
[ 0.000000] SMBIOS 3.1.1 present.
[ 0.000000] DMI: HPE ProLiant DL380 Gen10/ProLiant DL380 Gen10, BIOS U30 02/15/2018
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x103ffff max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: write-back
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000C0000000 mask 3FFFC0000000 uncachable
[ 0.000000] 1 base 0C0000000000 mask 3E0000000000 uncachable
[ 0.000000] 2 base 0000BF000000 mask 3FFFFF000000 uncachable
[ 0.000000] 3 base 0000D4000000 mask 3FFFFC000000 write-protect
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000000] x2apic: enabled by BIOS, switching to x2apic ops
[ 0.000000] e820: last_pfn = 0xaf800 max_arch_pfn = 0x400000000
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ (ptrval)] 99000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] BRK [0xe6233f000, 0xe6233ffff] PGTABLE
[ 0.000000] BRK [0xe62340000, 0xe62340fff] PGTABLE
[ 0.000000] BRK [0xe62341000, 0xe62341fff] PGTABLE
[ 0.000000] BRK [0xe62342000, 0xe62342fff] PGTABLE
[ 0.000000] BRK [0xe62343000, 0xe62343fff] PGTABLE
[ 0.000000] BRK [0xe62344000, 0xe62344fff] PGTABLE
[ 0.000000] BRK [0xe62345000, 0xe62345fff] PGTABLE
[ 0.000000] BRK [0xe62346000, 0xe62346fff] PGTABLE
[ 0.000000] BRK [0xe62347000, 0xe62347fff] PGTABLE
[ 0.000000] BRK [0xe62348000, 0xe62348fff] PGTABLE
[ 0.000000] BRK [0xe62349000, 0xe62349fff] PGTABLE
[ 0.000000] BRK [0xe6234a000, 0xe6234afff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x31808000-0x34bfbfff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x000000009D431014 000024 (v02 HPE )
[ 0.000000] ACPI: XSDT 0x000000009D41B188 00010C (v01 HPE Server 00000001 01000013)
[ 0.000000] ACPI: FACP 0x000000009D426000 00010C (v06 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: DSDT 0x000000009D414000 003960 (v02 HPE Server 00000002 HPAG 00020000)
[ 0.000000] ACPI: FACS 0x000000009CC8B000 000040
[ 0.000000] ACPI: UEFI 0x000000009D1AA000 000042 (v01 HPE Server 00000002 01000013)
[ 0.000000] ACPI: MCEJ 0x000000009D42F000 000130 (v01 HPE Server 00000002 INTL 20091013)
[ 0.000000] ACPI: PCAT 0x000000009D42D000 000048 (v01 HPE Server 00000002 INTL 20091013)
[ 0.000000] ACPI: SSDT 0x000000009D42E000 00003A (v01 HPE PLATOPRG 00000001 INTL 20140828)
[ 0.000000] ACPI: HEST 0x000000009D42C000 0000E8 (v01 HPE Server 00000001 INTL 00000001)
[ 0.000000] ACPI: BERT 0x000000009D42B000 000030 (v01 HPE Server 00000001 INTL 00000001)
[ 0.000000] ACPI: ERST 0x000000009D42A000 000250 (v01 HPE Server 00000001 INTL 00000001)
[ 0.000000] ACPI: EINJ 0x000000009D429000 000170 (v01 HPE Server 00000001 INTL 00000001)
[ 0.000000] ACPI: FPDT 0x000000009D428000 000034 (v01 HPE Server 00000002 01000013)
[ 0.000000] ACPI: BGRT 0x000000009D427000 000038 (v01 HPE Server 00000002 1590 01000013)
[ 0.000000] ACPI: HPET 0x000000009D425000 000038 (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: WDDT 0x000000009D424000 000040 (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: APIC 0x000000009D423000 00042C (v03 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: MCFG 0x000000009D422000 00003C (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: SLIT 0x000000009D421000 000030 (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: SRAT 0x000000009D420000 0003A8 (v03 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: SPMI 0x000000009D41F000 000041 (v05 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: RASF 0x000000009D41E000 000030 (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: SPCR 0x000000009D41D000 000050 (v02 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: MSCT 0x000000009D41C000 000064 (v02 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: BDAT 0x000000009D430000 000030 (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: WSMT 0x000000009D41A000 000028 (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: PCCT 0x000000009D419000 000030 (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: DMAR 0x000000009D418000 000230 (v01 HPE Server 00000001 1590 00000001)
[ 0.000000] ACPI: SSDT 0x000000009D40F000 004B73 (v02 HPE PCISSDT 00000002 HPAG 00020000)
[ 0.000000] ACPI: SSDT 0x000000009D40E000 0001CB (v02 HPE TIMESSDT 00000002 HPAG 00020000)
[ 0.000000] ACPI: SSDT 0x000000009D40D000 0002F2 (v01 HPE pmab 00000001 INTL 20140828)
[ 0.000000] ACPI: OEM1 0x000000009D40C000 000580 (v02 HPE CPU CPC 00000002 HPAG 00020000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] Setting APIC routing to cluster x2apic.
[ 0.000000] SRAT: PXM 0 -> APIC 0x0000 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x0002 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x0004 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x0006 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x0008 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x000a -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x000c -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x000e -> Node 0
[ 0.000000] SRAT: PXM 1 -> APIC 0x0010 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x0012 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x0014 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x0016 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x0018 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x001a -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x001c -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x001e -> Node 1
[ 0.000000] SRAT: PXM 0 -> APIC 0x0001 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x0003 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x0005 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x0007 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x0009 -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x000b -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x000d -> Node 0
[ 0.000000] SRAT: PXM 0 -> APIC 0x000f -> Node 0
[ 0.000000] SRAT: PXM 1 -> APIC 0x0011 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x0013 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x0015 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x0017 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x0019 -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x001b -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x001d -> Node 1
[ 0.000000] SRAT: PXM 1 -> APIC 0x001f -> Node 1
[ 0.000000] ACPI: SRAT: Node 0 PXM 0 [mem 0x00000000-0xbfffffff]
[ 0.000000] ACPI: SRAT: Node 0 PXM 0 [mem 0x100000000-0x83fffffff]
[ 0.000000] ACPI: SRAT: Node 1 PXM 1 [mem 0x840000000-0x103fffffff]
[ 0.000000] NUMA: Initialized distance table, cnt=2
[ 0.000000] NUMA: Node 0 [mem 0x00000000-0xbfffffff] + [mem 0x100000000-0x83fffffff] -> [mem 0x00000000-0x83fffffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x83ffd5000-0x83fffffff]
[ 0.000000] NODE_DATA(1) allocated [mem 0x103ffd3000-0x103fffdfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000103fffefff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000008dfff]
[ 0.000000] node 0: [mem 0x0000000000090000-0x000000000009ffff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000865e0fff]
[ 0.000000] node 0: [mem 0x00000000865e4000-0x000000008f1e5fff]
[ 0.000000] node 0: [mem 0x0000000090200000-0x0000000090200fff]
[ 0.000000] node 0: [mem 0x0000000090216000-0x0000000090216fff]
[ 0.000000] node 0: [mem 0x0000000090932000-0x000000009a131fff]
[ 0.000000] node 0: [mem 0x000000009d432000-0x000000009d433fff]
[ 0.000000] node 0: [mem 0x000000009d4b5000-0x00000000af7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000083fffffff]
[ 0.000000] node 1: [mem 0x0000000840000000-0x000000103fffefff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000083fffffff]
[ 0.000000] On node 0 totalpages: 8301775
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 24 pages reserved
[ 0.000000] DMA zone: 3997 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 10869 pages used for memmap
[ 0.000000] DMA32 zone: 695602 pages, LIFO batch:31
[ 0.000000] Normal zone: 118784 pages used for memmap
[ 0.000000] Normal zone: 7602176 pages, LIFO batch:31
[ 0.000000] Initmem setup node 1 [mem 0x0000000840000000-0x000000103fffefff]
[ 0.000000] On node 1 totalpages: 8388607
[ 0.000000] Normal zone: 131072 pages used for memmap
[ 0.000000] Normal zone: 8388607 pages, LIFO batch:31
[ 0.000000] Reserved but unavailable: 97 pages
[ 0.000000] ACPI: PM-Timer IO Port: 0x508
[ 0.000000] ACPI: X2APIC_NMI (uid[0x00] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x01] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x02] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x03] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x04] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x05] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x06] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x07] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x08] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x09] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x0a] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x0b] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x0c] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x0d] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x0e] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x0f] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x10] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x11] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x12] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x13] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x14] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x15] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x16] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x17] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x18] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x19] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x1a] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x1b] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x1c] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x1d] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x1e] high level lint[0x1])
[ 0.000000] ACPI: X2APIC_NMI (uid[0x1f] high level lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 9, version 32, address 0xfec01000, GSI 24-31
[ 0.000000] IOAPIC[2]: apic_id 10, version 32, address 0xfec08000, GSI 32-39
[ 0.000000] IOAPIC[3]: apic_id 11, version 32, address 0xfec10000, GSI 40-47
[ 0.000000] IOAPIC[4]: apic_id 12, version 32, address 0xfec18000, GSI 48-55
[ 0.000000] IOAPIC[5]: apic_id 15, version 32, address 0xfec20000, GSI 56-63
[ 0.000000] IOAPIC[6]: apic_id 16, version 32, address 0xfec28000, GSI 64-71
[ 0.000000] IOAPIC[7]: apic_id 17, version 32, address 0xfec30000, GSI 72-79
[ 0.000000] IOAPIC[8]: apic_id 18, version 32, address 0xfec38000, GSI 80-87
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 32 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0008e000-0x0008ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000effff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x865e1000-0x865e3fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x8f1e6000-0x901fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x90201000-0x90215fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x90217000-0x90931fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x9a132000-0x9a531fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x9a532000-0x9ad31fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x9ad32000-0x9ae31fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x9ae32000-0x9d231fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x9d232000-0x9d431fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x9d434000-0x9d4b4fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xaf800000-0xcfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xd0000000-0xfdffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfe000000-0xfe00ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfe010000-0xffffffff]
[ 0.000000] e820: [mem 0xd0000000-0xfdffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] random: get_random_bytes called from start_kernel+0x99/0x51b with crng_init=0
[ 0.000000] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:32 nr_cpu_ids:32 nr_node_ids:2
[ 0.000000] percpu: Embedded 46 pages/cpu @ (ptrval) s151552 r8192 d28672 u262144
[ 0.000000] pcpu-alloc: s151552 r8192 d28672 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 16 17 18 19 20 21 22 23
[ 0.000000] pcpu-alloc: [1] 08 09 10 11 12 13 14 15 [1] 24 25 26 27 28 29 30 31
[ 0.000000] Built 2 zonelists, mobility grouping on. Total pages: 16429569
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-34-generic root=UUID=72fc1412-d8a1-4ba8-9458-e4d8d864e7bf ro quiet splash vt.handoff=7
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 65276272K/66761528K available (12300K kernel code, 2470K rwdata, 4256K rodata, 2408K init, 2416K bss, 1485256K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=2
[ 0.000000] Kernel/User page tables isolation: enabled
[ 0.000000] ftrace: allocating 39153 entries in 153 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=32.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.000000] NR_IRQS: 524544, nr_irqs: 1768, preallocated irqs: 16
[ 0.000000] vt handoff: transparent VT on vt#7
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] mempolicy: Enabling automatic NUMA balancing. Configure with numa_balancing= or the kernel.numa_balancing sysctl
[ 0.000000] ACPI: Core revision 20170831
[ 0.000000] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.000000] hpet clockevent registered
[ 0.004000] APIC: Switch to symmetric I/O mode setup
[ 0.004000] DMAR: Host address width 46
[ 0.004000] DMAR: DRHD base: 0x000000ef3fc000 flags: 0x0
[ 0.004000] DMAR: dmar0: reg_base_addr ef3fc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.004000] DMAR: DRHD base: 0x000000f37fc000 flags: 0x0
[ 0.004000] DMAR: dmar1: reg_base_addr f37fc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.004000] DMAR: DRHD base: 0x000000f7bfc000 flags: 0x0
[ 0.004000] DMAR: dmar2: reg_base_addr f7bfc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.004000] DMAR: DRHD base: 0x000000fbffc000 flags: 0x0
[ 0.004000] DMAR: dmar3: reg_base_addr fbffc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.004000] DMAR: DRHD base: 0x000000e27fc000 flags: 0x0
[ 0.004000] DMAR: dmar4: reg_base_addr e27fc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.004000] DMAR: DRHD base: 0x000000e6bfc000 flags: 0x0
[ 0.004000] DMAR: dmar5: reg_base_addr e6bfc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.004000] DMAR: DRHD base: 0x000000eaffc000 flags: 0x0
[ 0.004000] DMAR: dmar6: reg_base_addr eaffc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.004000] DMAR: DRHD base: 0x000000de3fc000 flags: 0x1
[ 0.004000] DMAR: dmar7: reg_base_addr de3fc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.004000] DMAR: RMRR base: 0x0000009cc88000 end: 0x0000009cc8afff
[ 0.004000] DMAR: RMRR base: 0x0000009ad91000 end: 0x0000009ad91fff
[ 0.004000] DMAR: ATSR flags: 0x0
[ 0.004000] DMAR-IR: IOAPIC id 12 under DRHD base 0xeaffc000 IOMMU 6
[ 0.004000] DMAR-IR: IOAPIC id 11 under DRHD base 0xe6bfc000 IOMMU 5
[ 0.004000] DMAR-IR: IOAPIC id 10 under DRHD base 0xe27fc000 IOMMU 4
[ 0.004000] DMAR-IR: IOAPIC id 18 under DRHD base 0xfbffc000 IOMMU 3
[ 0.004000] DMAR-IR: IOAPIC id 17 under DRHD base 0xf7bfc000 IOMMU 2
[ 0.004000] DMAR-IR: IOAPIC id 16 under DRHD base 0xf37fc000 IOMMU 1
[ 0.004000] DMAR-IR: IOAPIC id 15 under DRHD base 0xef3fc000 IOMMU 0
[ 0.004000] DMAR-IR: IOAPIC id 8 under DRHD base 0xde3fc000 IOMMU 7
[ 0.004000] DMAR-IR: IOAPIC id 9 under DRHD base 0xde3fc000 IOMMU 7
[ 0.004000] DMAR-IR: HPET id 0 under DRHD base 0xde3fc000
[ 0.004000] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.004000] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.004000] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.024000] tsc: Detected 1800.000 MHz processor
[ 0.024000] Calibrating delay loop (skipped), value calculated using timer frequency… 3600.00 BogoMIPS (lpj=7200000)
[ 0.024000] pid_max: default: 32768 minimum: 301
[ 0.024000] Security Framework initialized
[ 0.024000] Yama: becoming mindful.
[ 0.024000] AppArmor: AppArmor initialized
[ 0.036935] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes)
[ 0.042833] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.043063] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.043247] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.043640] mce: CPU supports 20 MCE banks
[ 0.043657] CPU0: Thermal monitoring enabled (TM1)
[ 0.043685] process: using mwait in idle threads
[ 0.043689] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.043690] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.043693] Spectre V2 : Mitigation: Full generic retpoline
[ 0.043693] Spectre V2 : Spectre v2 mitigation: Filling RSB on context switch
[ 0.043694] Spectre V2 : Spectre v2 mitigation: Enabling Indirect Branch Prediction Barrier
[ 0.043695] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.043696] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.054001] Freeing SMP alternatives memory: 36K
[ 0.063490] TSC deadline timer enabled
[ 0.063496] smpboot: CPU0: Intel® Xeon® Silver 4108 CPU @ 1.80GHz (family: 0x6, model: 0x55, stepping: 0x4)
[ 0.063651] Performance Events: PEBS fmt3+, Skylake events, full-width counters, Intel PMU driver.
[ 0.063663] … version: 4
[ 0.063664] … bit width: 48
[ 0.063665] … generic registers: 4
[ 0.063666] … value mask: 0000ffffffffffff
[ 0.063667] … max period: 00007fffffffffff
[ 0.063667] … fixed-purpose events: 3
[ 0.063668] … event mask: 000000070000000f
[ 0.063725] Hierarchical SRCU implementation.
[ 0.065964] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.065983] smp: Bringing up secondary CPUs …
[ 0.066078] x86: Booting SMP configuration:
[ 0.066079] … node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
[ 0.140118] … node #1, CPUs: #8 #9 #10 #11 #12 #13 #14 #15
[ 0.315197] … node #0, CPUs: #16 #17 #18 #19 #20 #21 #22 #23
[ 0.334569] … node #1, CPUs: #24 #25 #26 #27 #28 #29 #30 #31
[ 0.356932] smp: Brought up 2 nodes, 32 CPUs
[ 0.356932] smpboot: Max logical packages: 2
[ 0.356932] smpboot: Total of 32 processors activated (115225.28 BogoMIPS)
[ 0.362793] devtmpfs: initialized
[ 0.362793] x86/mm: Memory block size: 2048MB
[ 0.362793] evm: security.selinux
[ 0.362793] evm: security.SMACK64
[ 0.362793] evm: security.SMACK64EXEC
[ 0.362793] evm: security.SMACK64TRANSMUTE
[ 0.362793] evm: security.SMACK64MMAP
[ 0.362793] evm: security.apparmor
[ 0.362793] evm: security.ima
[ 0.362793] evm: security.capability
[ 0.362793] PM: Registering ACPI NVS region [mem 0x9ae32000-0x9d231fff] (37748736 bytes)
[ 0.364377] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.364377] futex hash table entries: 8192 (order: 7, 524288 bytes)
[ 0.364377] pinctrl core: initialized pinctrl subsystem
[ 0.364493] RTC time: 6:05:38, date: 09/19/18
[ 0.365834] NET: Registered protocol family 16
[ 0.365961] audit: initializing netlink subsys (disabled)
[ 0.365967] audit: type=2000 audit(1537337137.364:1): state=initialized audit_enabled=0 res=1
[ 0.365967] cpuidle: using governor ladder
[ 0.365967] cpuidle: using governor menu
[ 0.365967] Invalid PCCT: 0 PCC subspaces
[ 0.365967] ACPI FADT declares the system doesn’t support PCIe ASPM, so disable it
[ 0.365967] ACPI: bus type PCI registered
[ 0.365967] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.365967] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xc0000000-0xcfffffff] (base 0xc0000000)
[ 0.365967] PCI: MMCONFIG at [mem 0xc0000000-0xcfffffff] reserved in E820
[ 0.365967] PCI: Using configuration type 1 for base access
[ 0.365967] PCI: HP ProLiant DL380 detected, enabling pci=bfsort.
[ 0.371337] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.371337] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.372013] ACPI: Added _OSI(Module Device)
[ 0.372013] ACPI: Added _OSI(Processor Device)
[ 0.372013] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.372013] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.372013] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.372013] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.380598] ACPI: Interpreter enabled
[ 0.380611] ACPI: (supports S0 S5)
[ 0.380612] ACPI: Using IOAPIC for interrupt routing
[ 0.380672] HEST: Table parsing has been initialized.
[ 0.380675] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 0.380752] ACPI: Enabled 3 GPEs in block 00 to 7F
[ 0.394865] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-10])
[ 0.394878] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.395044] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.395196] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.395198] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.395198] PCI host bridge to bus 0000:00
[ 0.395198] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000cbfff window]
[ 0.395198] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.395198] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.395198] pci_bus 0000:00: root bus resource [io 0x03b0-0x03bb window]
[ 0.395198] pci_bus 0000:00: root bus resource [io 0x03c0-0x03df window]
[ 0.395198] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.395198] pci_bus 0000:00: root bus resource [io 0x1000-0x3fff window]
[ 0.395198] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xde3fbfff window]
[ 0.395198] pci_bus 0000:00: root bus resource [mem 0xc0000000000-0xc3fffffffff window]
[ 0.395198] pci_bus 0000:00: root bus resource [bus 00-10]
[ 0.395198] pci 0000:00:00.0: [8086:2020] type 00 class 0x060000
[ 0.395198] pci 0000:00:04.0: [8086:2021] type 00 class 0x088000
[ 0.395198] pci 0000:00:04.0: reg 0x10: [mem 0xc3ffff1c000-0xc3ffff1ffff 64bit]
[ 0.395198] pci 0000:00:04.1: [8086:2021] type 00 class 0x088000
[ 0.395198] pci 0000:00:04.1: reg 0x10: [mem 0xc3ffff18000-0xc3ffff1bfff 64bit]
[ 0.395198] pci 0000:00:04.2: [8086:2021] type 00 class 0x088000
[ 0.395198] pci 0000:00:04.2: reg 0x10: [mem 0xc3ffff14000-0xc3ffff17fff 64bit]
[ 0.395198] pci 0000:00:04.3: [8086:2021] type 00 class 0x088000
[ 0.395198] pci 0000:00:04.3: reg 0x10: [mem 0xc3ffff10000-0xc3ffff13fff 64bit]
[ 0.395198] pci 0000:00:04.4: [8086:2021] type 00 class 0x088000
[ 0.395198] pci 0000:00:04.4: reg 0x10: [mem 0xc3ffff0c000-0xc3ffff0ffff 64bit]
[ 0.395198] pci 0000:00:04.5: [8086:2021] type 00 class 0x088000
[ 0.395198] pci 0000:00:04.5: reg 0x10: [mem 0xc3ffff08000-0xc3ffff0bfff 64bit]
[ 0.395198] pci 0000:00:04.6: [8086:2021] type 00 class 0x088000
[ 0.395198] pci 0000:00:04.6: reg 0x10: [mem 0xc3ffff04000-0xc3ffff07fff 64bit]
[ 0.395198] pci 0000:00:04.7: [8086:2021] type 00 class 0x088000
[ 0.395198] pci 0000:00:04.7: reg 0x10: [mem 0xc3ffff00000-0xc3ffff03fff 64bit]
[ 0.395198] pci 0000:00:05.0: [8086:2024] type 00 class 0x088000
[ 0.395198] pci 0000:00:05.2: [8086:2025] type 00 class 0x088000
[ 0.395198] pci 0000:00:05.4: [8086:2026] type 00 class 0x080020
[ 0.395198] pci 0000:00:05.4: reg 0x10: [mem 0xd9e97000-0xd9e97fff]
[ 0.395198] pci 0000:00:08.0: [8086:2014] type 00 class 0x088000
[ 0.395198] pci 0000:00:08.1: [8086:2015] type 00 class 0x110100
[ 0.395198] pci 0000:00:08.2: [8086:2016] type 00 class 0x088000
[ 0.395198] pci 0000:00:11.0: [8086:a1ec] type 00 class 0xff0000
[ 0.395198] pci 0000:00:11.1: [8086:a1ed] type 00 class 0xff0000
[ 0.395232] pci 0000:00:11.5: [8086:a1d2] type 00 class 0x010601
[ 0.395250] pci 0000:00:11.5: reg 0x10: [mem 0xd9e94000-0xd9e95fff]
[ 0.395258] pci 0000:00:11.5: reg 0x14: [mem 0xd9e96000-0xd9e960ff]
[ 0.395266] pci 0000:00:11.5: reg 0x18: [io 0x2040-0x2047]
[ 0.395274] pci 0000:00:11.5: reg 0x1c: [io 0x2048-0x204b]
[ 0.395281] pci 0000:00:11.5: reg 0x20: [io 0x2020-0x203f]
[ 0.395289] pci 0000:00:11.5: reg 0x24: [mem 0xd9e00000-0xd9e7ffff]
[ 0.395329] pci 0000:00:11.5: PME# supported from D3hot
[ 0.395482] pci 0000:00:14.0: [8086:a1af] type 00 class 0x0c0330
[ 0.395504] pci 0000:00:14.0: reg 0x10: [mem 0xd9e80000-0xd9e8ffff 64bit]
[ 0.395570] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.395731] pci 0000:00:14.2: [8086:a1b1] type 00 class 0x118000
[ 0.395752] pci 0000:00:14.2: reg 0x10: [mem 0xc3ffff23000-0xc3ffff23fff 64bit]
[ 0.395957] pci 0000:00:16.0: [8086:a1ba] type 00 class 0x078000
[ 0.395986] pci 0000:00:16.0: reg 0x10: [mem 0xc3ffff22000-0xc3ffff22fff 64bit]
[ 0.396073] pci 0000:00:16.0: PME# supported from D3hot
[ 0.396224] pci 0000:00:16.4: [8086:a1be] type 00 class 0x078000
[ 0.396251] pci 0000:00:16.4: reg 0x10: [mem 0xc3ffff21000-0xc3ffff21fff 64bit]
[ 0.396326] pci 0000:00:16.4: PME# supported from D3hot
[ 0.396478] pci 0000:00:1c.0: [8086:a190] type 01 class 0x060400
[ 0.396545] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.396704] pci 0000:00:1c.4: [8086:a194] type 01 class 0x060400
[ 0.396770] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.396928] pci 0000:00:1f.0: [8086:a1c1] type 00 class 0x060100
[ 0.397136] pci 0000:00:1f.2: [8086:a1a1] type 00 class 0x058000
[ 0.397151] pci 0000:00:1f.2: reg 0x10: [mem 0xd9e90000-0xd9e93fff]
[ 0.397414] pci 0000:02:00.0: [14e4:1657] type 00 class 0x020000
[ 0.397446] pci 0000:02:00.0: reg 0x10: [mem 0xd9d90000-0xd9d9ffff 64bit pref]
[ 0.397462] pci 0000:02:00.0: reg 0x18: [mem 0xd9da0000-0xd9daffff 64bit pref]
[ 0.397477] pci 0000:02:00.0: reg 0x20: [mem 0xd9db0000-0xd9dbffff 64bit pref]
[ 0.397488] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0003ffff pref]
[ 0.397574] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.397708] pci 0000:02:00.1: [14e4:1657] type 00 class 0x020000
[ 0.397740] pci 0000:02:00.1: reg 0x10: [mem 0xd9d60000-0xd9d6ffff 64bit pref]
[ 0.397755] pci 0000:02:00.1: reg 0x18: [mem 0xd9d70000-0xd9d7ffff 64bit pref]
[ 0.397771] pci 0000:02:00.1: reg 0x20: [mem 0xd9d80000-0xd9d8ffff 64bit pref]
[ 0.397782] pci 0000:02:00.1: reg 0x30: [mem 0x00000000-0x0003ffff pref]
[ 0.397867] pci 0000:02:00.1: PME# supported from D0 D3hot D3cold
[ 0.397988] pci 0000:02:00.2: [14e4:1657] type 00 class 0x020000
[ 0.398020] pci 0000:02:00.2: reg 0x10: [mem 0xd9d30000-0xd9d3ffff 64bit pref]
[ 0.398036] pci 0000:02:00.2: reg 0x18: [mem 0xd9d40000-0xd9d4ffff 64bit pref]
[ 0.398051] pci 0000:02:00.2: reg 0x20: [mem 0xd9d50000-0xd9d5ffff 64bit pref]
[ 0.398062] pci 0000:02:00.2: reg 0x30: [mem 0x00000000-0x0003ffff pref]
[ 0.398146] pci 0000:02:00.2: PME# supported from D0 D3hot D3cold
[ 0.398268] pci 0000:02:00.3: [14e4:1657] type 00 class 0x020000
[ 0.398300] pci 0000:02:00.3: reg 0x10: [mem 0xd9d00000-0xd9d0ffff 64bit pref]
[ 0.398315] pci 0000:02:00.3: reg 0x18: [mem 0xd9d10000-0xd9d1ffff 64bit pref]
[ 0.398331] pci 0000:02:00.3: reg 0x20: [mem 0xd9d20000-0xd9d2ffff 64bit pref]
[ 0.398341] pci 0000:02:00.3: reg 0x30: [mem 0x00000000-0x0003ffff pref]
[ 0.398426] pci 0000:02:00.3: PME# supported from D0 D3hot D3cold
[ 0.398558] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.398566] pci 0000:00:1c.0: bridge window [mem 0xd9d00000-0xd9dfffff 64bit pref]
[ 0.398614] pci 0000:01:00.0: [103c:3306] type 00 class 0x088000
[ 0.398636] pci 0000:01:00.0: reg 0x10: [io 0x1200-0x12ff]
[ 0.398647] pci 0000:01:00.0: reg 0x14: [mem 0xd9b9e000-0xd9b9e3ff]
[ 0.398657] pci 0000:01:00.0: reg 0x18: [io 0x1100-0x11ff]
[ 0.398667] pci 0000:01:00.0: reg 0x1c: [mem 0xd4000000-0xd7ffffff]
[ 0.398677] pci 0000:01:00.0: reg 0x20: [mem 0xd9800000-0xd99fffff]
[ 0.398804] pci 0000:01:00.1: [102b:0538] type 00 class 0x030000
[ 0.398826] pci 0000:01:00.1: reg 0x10: [mem 0xd8000000-0xd8ffffff pref]
[ 0.398836] pci 0000:01:00.1: reg 0x14: [mem 0xd9b98000-0xd9b9bfff]
[ 0.398846] pci 0000:01:00.1: reg 0x18: [mem 0xd9000000-0xd97fffff]
[ 0.398897] pci 0000:01:00.1: BAR 0: assigned to efifb
[ 0.398988] pci 0000:01:00.2: [103c:3307] type 00 class 0x088000
[ 0.399010] pci 0000:01:00.2: reg 0x10: [io 0x1000-0x10ff]
[ 0.399021] pci 0000:01:00.2: reg 0x14: [mem 0xd9b9d000-0xd9b9d0ff]
[ 0.399031] pci 0000:01:00.2: reg 0x18: [mem 0xd9a00000-0xd9afffff]
[ 0.399041] pci 0000:01:00.2: reg 0x1c: [mem 0xd9b00000-0xd9b7ffff]
[ 0.399051] pci 0000:01:00.2: reg 0x20: [mem 0xd9b90000-0xd9b97fff]
[ 0.399061] pci 0000:01:00.2: reg 0x24: [mem 0xd9b80000-0xd9b8ffff]
[ 0.399071] pci 0000:01:00.2: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.399125] pci 0000:01:00.2: PME# supported from D0 D3hot D3cold
[ 0.399180] pci 0000:01:00.4: [103c:22f6] type 00 class 0x0c0320
[ 0.399202] pci 0000:01:00.4: reg 0x10: [mem 0xd9b9c000-0xd9b9c0ff]
[ 0.399354] pci 0000:00:1c.4: PCI bridge to [bus 01]
[ 0.399357] pci 0000:00:1c.4: bridge window [io 0x1000-0x1fff]
[ 0.399360] pci 0000:00:1c.4: bridge window [mem 0xd0000000-0xd9bfffff]
[ 0.399374] pci_bus 0000:00: on NUMA node 0
[ 0.399611] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.399685] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.399755] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.399825] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.399897] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.399966] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.400038] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.400106] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.400430] ACPI: PCI Root Bridge [PC01] (domain 0000 [bus 11-35])
[ 0.400440] acpi PNP0A08:01: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.400593] acpi PNP0A08:01: _OSC: platform does not support [AER]
[ 0.400733] acpi PNP0A08:01: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.400734] acpi PNP0A08:01: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.400818] PCI host bridge to bus 0000:11
[ 0.400820] pci_bus 0000:11: root bus resource [io 0x4000-0x5fff window]
[ 0.400822] pci_bus 0000:11: root bus resource [mem 0xde400000-0xe27fbfff window]
[ 0.400824] pci_bus 0000:11: root bus resource [mem 0xc4000000000-0xc7fffffffff window]
[ 0.400825] pci_bus 0000:11: root bus resource [bus 11-35]
[ 0.400835] pci 0000:11:00.0: [8086:2030] type 01 class 0x060400
[ 0.400862] pci 0000:11:00.0: enabling Extended Tags
[ 0.400894] pci 0000:11:00.0: PME# supported from D0 D3hot D3cold
[ 0.400960] pci 0000:11:02.0: [8086:2032] type 01 class 0x060400
[ 0.400985] pci 0000:11:02.0: enabling Extended Tags
[ 0.401016] pci 0000:11:02.0: PME# supported from D0 D3hot D3cold
[ 0.401076] pci 0000:11:05.0: [8086:2034] type 00 class 0x088000
[ 0.401156] pci 0000:11:05.2: [8086:2035] type 00 class 0x088000
[ 0.401234] pci 0000:11:05.4: [8086:2036] type 00 class 0x080020
[ 0.401244] pci 0000:11:05.4: reg 0x10: [mem 0xde400000-0xde400fff]
[ 0.401325] pci 0000:11:08.0: [8086:208d] type 00 class 0x088000
[ 0.401389] pci 0000:11:08.1: [8086:208d] type 00 class 0x088000
[ 0.401443] pci 0000:11:08.2: [8086:208d] type 00 class 0x088000
[ 0.401497] pci 0000:11:08.3: [8086:208d] type 00 class 0x088000
[ 0.401550] pci 0000:11:08.4: [8086:208d] type 00 class 0x088000
[ 0.401606] pci 0000:11:08.5: [8086:208d] type 00 class 0x088000
[ 0.401659] pci 0000:11:08.6: [8086:208d] type 00 class 0x088000
[ 0.401713] pci 0000:11:08.7: [8086:208d] type 00 class 0x088000
[ 0.401767] pci 0000:11:09.0: [8086:208d] type 00 class 0x088000
[ 0.401822] pci 0000:11:09.1: [8086:208d] type 00 class 0x088000
[ 0.401880] pci 0000:11:0e.0: [8086:208e] type 00 class 0x088000
[ 0.401936] pci 0000:11:0e.1: [8086:208e] type 00 class 0x088000
[ 0.401988] pci 0000:11:0e.2: [8086:208e] type 00 class 0x088000
[ 0.402041] pci 0000:11:0e.3: [8086:208e] type 00 class 0x088000
[ 0.402094] pci 0000:11:0e.4: [8086:208e] type 00 class 0x088000
[ 0.402148] pci 0000:11:0e.5: [8086:208e] type 00 class 0x088000
[ 0.402202] pci 0000:11:0e.6: [8086:208e] type 00 class 0x088000
[ 0.402258] pci 0000:11:0e.7: [8086:208e] type 00 class 0x088000
[ 0.402311] pci 0000:11:0f.0: [8086:208e] type 00 class 0x088000
[ 0.402363] pci 0000:11:0f.1: [8086:208e] type 00 class 0x088000
[ 0.402428] pci 0000:11:1d.0: [8086:2054] type 00 class 0x088000
[ 0.402481] pci 0000:11:1d.1: [8086:2055] type 00 class 0x088000
[ 0.402534] pci 0000:11:1d.2: [8086:2056] type 00 class 0x088000
[ 0.402590] pci 0000:11:1d.3: [8086:2057] type 00 class 0x088000
[ 0.402646] pci 0000:11:1e.0: [8086:2080] type 00 class 0x088000
[ 0.402701] pci 0000:11:1e.1: [8086:2081] type 00 class 0x088000
[ 0.402753] pci 0000:11:1e.2: [8086:2082] type 00 class 0x088000
[ 0.402807] pci 0000:11:1e.3: [8086:2083] type 00 class 0x088000
[ 0.402861] pci 0000:11:1e.4: [8086:2084] type 00 class 0x088000
[ 0.402916] pci 0000:11:1e.5: [8086:2085] type 00 class 0x088000
[ 0.402970] pci 0000:11:1e.6: [8086:2086] type 00 class 0x088000
[ 0.403053] pci 0000:11:00.0: PCI bridge to [bus 12]
[ 0.403085] pci 0000:11:02.0: PCI bridge to [bus 13]
[ 0.403100] pci_bus 0000:11: on NUMA node 0
[ 0.403142] ACPI: PCI Root Bridge [PC02] (domain 0000 [bus 36-5a])
[ 0.403152] acpi PNP0A08:02: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.403304] acpi PNP0A08:02: _OSC: platform does not support [AER]
[ 0.403443] acpi PNP0A08:02: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.403445] acpi PNP0A08:02: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.403529] PCI host bridge to bus 0000:36
[ 0.403531] pci_bus 0000:36: root bus resource [io 0x6000-0x7fff window]
[ 0.403532] pci_bus 0000:36: root bus resource [mem 0xe2800000-0xe6bfbfff window]
[ 0.403534] pci_bus 0000:36: root bus resource [mem 0xc8000000000-0xcbfffffffff window]
[ 0.403535] pci_bus 0000:36: root bus resource [bus 36-5a]
[ 0.403544] pci 0000:36:00.0: [8086:2030] type 01 class 0x060400
[ 0.403598] pci 0000:36:00.0: PME# supported from D0 D3hot D3cold
[ 0.403703] pci 0000:36:05.0: [8086:2034] type 00 class 0x088000
[ 0.403783] pci 0000:36:05.2: [8086:2035] type 00 class 0x088000
[ 0.403860] pci 0000:36:05.4: [8086:2036] type 00 class 0x080020
[ 0.403870] pci 0000:36:05.4: reg 0x10: [mem 0xe4000000-0xe4000fff]
[ 0.403953] pci 0000:36:08.0: [8086:2066] type 00 class 0x088000
[ 0.404025] pci 0000:36:09.0: [8086:2066] type 00 class 0x088000
[ 0.404097] pci 0000:36:0a.0: [8086:2040] type 00 class 0x088000
[ 0.404164] pci 0000:36:0a.1: [8086:2041] type 00 class 0x088000
[ 0.404232] pci 0000:36:0a.2: [8086:2042] type 00 class 0x088000
[ 0.404300] pci 0000:36:0a.3: [8086:2043] type 00 class 0x088000
[ 0.404372] pci 0000:36:0a.4: [8086:2044] type 00 class 0x088000
[ 0.404439] pci 0000:36:0a.5: [8086:2045] type 00 class 0x088000
[ 0.404505] pci 0000:36:0a.6: [8086:2046] type 00 class 0x088000
[ 0.404573] pci 0000:36:0a.7: [8086:2047] type 00 class 0x088000
[ 0.404638] pci 0000:36:0b.0: [8086:2048] type 00 class 0x088000
[ 0.404704] pci 0000:36:0b.1: [8086:2049] type 00 class 0x088000
[ 0.404771] pci 0000:36:0b.2: [8086:204a] type 00 class 0x088000
[ 0.404843] pci 0000:36:0b.3: [8086:204b] type 00 class 0x088000
[ 0.404912] pci 0000:36:0c.0: [8086:2040] type 00 class 0x088000
[ 0.404978] pci 0000:36:0c.1: [8086:2041] type 00 class 0x088000
[ 0.405046] pci 0000:36:0c.2: [8086:2042] type 00 class 0x088000
[ 0.405113] pci 0000:36:0c.3: [8086:2043] type 00 class 0x088000
[ 0.405179] pci 0000:36:0c.4: [8086:2044] type 00 class 0x088000
[ 0.405246] pci 0000:36:0c.5: [8086:2045] type 00 class 0x088000
[ 0.405313] pci 0000:36:0c.6: [8086:2046] type 00 class 0x088000
[ 0.405380] pci 0000:36:0c.7: [8086:2047] type 00 class 0x088000
[ 0.405449] pci 0000:36:0d.0: [8086:2048] type 00 class 0x088000
[ 0.405515] pci 0000:36:0d.1: [8086:2049] type 00 class 0x088000
[ 0.405581] pci 0000:36:0d.2: [8086:204a] type 00 class 0x088000
[ 0.405648] pci 0000:36:0d.3: [8086:204b] type 00 class 0x088000
[ 0.405837] pci 0000:37:00.0: [10de:1bb3] type 00 class 0x030200
[ 0.405850] pci 0000:37:00.0: reg 0x10: [mem 0xe3000000-0xe3ffffff]
[ 0.405858] pci 0000:37:00.0: reg 0x14: [mem 0xcbfe0000000-0xcbfefffffff 64bit pref]
[ 0.405865] pci 0000:37:00.0: reg 0x1c: [mem 0xcbff0000000-0xcbff1ffffff 64bit pref]
[ 0.405972] pci 0000:36:00.0: PCI bridge to [bus 37]
[ 0.405976] pci 0000:36:00.0: bridge window [mem 0xe3000000-0xe3ffffff]
[ 0.405979] pci 0000:36:00.0: bridge window [mem 0xcbfe0000000-0xcbff1ffffff 64bit pref]
[ 0.405986] pci_bus 0000:36: on NUMA node 0
[ 0.406040] ACPI: PCI Root Bridge [PC03] (domain 0000 [bus 5b-7f])
[ 0.406049] acpi PNP0A08:03: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.406202] acpi PNP0A08:03: _OSC: platform does not support [AER]
[ 0.406341] acpi PNP0A08:03: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.406342] acpi PNP0A08:03: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.406421] PCI host bridge to bus 0000:5b
[ 0.406423] pci_bus 0000:5b: root bus resource [io 0x8000-0x9fff window]
[ 0.406425] pci_bus 0000:5b: root bus resource [mem 0xe6c00000-0xeaffbfff window]
[ 0.406426] pci_bus 0000:5b: root bus resource [mem 0xcc000000000-0xcffffffffff window]
[ 0.406428] pci_bus 0000:5b: root bus resource [bus 5b-7f]
[ 0.406437] pci 0000:5b:00.0: [8086:2030] type 01 class 0x060400
[ 0.406494] pci 0000:5b:00.0: PME# supported from D0 D3hot D3cold
[ 0.406554] pci 0000:5b:02.0: [8086:2032] type 01 class 0x060400
[ 0.406581] pci 0000:5b:02.0: enabling Extended Tags
[ 0.406612] pci 0000:5b:02.0: PME# supported from D0 D3hot D3cold
[ 0.406673] pci 0000:5b:05.0: [8086:2034] type 00 class 0x088000
[ 0.406754] pci 0000:5b:05.2: [8086:2035] type 00 class 0x088000
[ 0.406830] pci 0000:5b:05.4: [8086:2036] type 00 class 0x080020
[ 0.406840] pci 0000:5b:05.4: reg 0x10: [mem 0xe6d00000-0xe6d00fff]
[ 0.406922] pci 0000:5b:0e.0: [8086:2058] type 00 class 0x110100
[ 0.406988] pci 0000:5b:0e.1: [8086:2059] type 00 class 0x088000
[ 0.407055] pci 0000:5b:0f.0: [8086:2058] type 00 class 0x110100
[ 0.407119] pci 0000:5b:0f.1: [8086:2059] type 00 class 0x088000
[ 0.407189] pci 0000:5b:12.0: [8086:204c] type 00 class 0x110100
[ 0.407253] pci 0000:5b:12.1: [8086:204d] type 00 class 0x110100
[ 0.407308] pci 0000:5b:12.2: [8086:204e] type 00 class 0x088000
[ 0.407364] pci 0000:5b:15.0: [8086:2018] type 00 class 0x088000
[ 0.407421] pci 0000:5b:16.0: [8086:2018] type 00 class 0x088000
[ 0.407478] pci 0000:5b:16.4: [8086:2018] type 00 class 0x088000
[ 0.407575] pci 0000:5c:00.0: [9005:028f] type 00 class 0x010700
[ 0.407591] pci 0000:5c:00.0: reg 0x10: [mem 0xe6c00000-0xe6c07fff 64bit]
[ 0.407606] pci 0000:5c:00.0: reg 0x20: [io 0x8000-0x80ff]
[ 0.407617] pci 0000:5c:00.0: reg 0x30: [mem 0x00000000-0x001fffff pref]
[ 0.407651] pci 0000:5c:00.0: supports D1
[ 0.407653] pci 0000:5c:00.0: PME# supported from D0 D1 D3hot
[ 0.420027] pci 0000:5b:00.0: PCI bridge to [bus 5c]
[ 0.420033] pci 0000:5b:00.0: bridge window [io 0x8000-0x8fff]
[ 0.420039] pci 0000:5b:00.0: bridge window [mem 0xe6c00000-0xe6cfffff]
[ 0.420112] pci 0000:5b:02.0: PCI bridge to [bus 5d]
[ 0.420143] pci_bus 0000:5b: on NUMA node 0
[ 0.420238] ACPI: PCI Root Bridge [PC06] (domain 0000 [bus 80-84])
[ 0.420263] acpi PNP0A08:04: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.420620] acpi PNP0A08:04: _OSC: platform does not support [AER]
[ 0.420988] acpi PNP0A08:04: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.420991] acpi PNP0A08:04: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.421132] PCI host bridge to bus 0000:80
[ 0.421138] pci_bus 0000:80: root bus resource [mem 0xeb000000-0xef3fbfff window]
[ 0.421142] pci_bus 0000:80: root bus resource [mem 0xd0000000000-0xd3fffffffff window]
[ 0.421146] pci_bus 0000:80: root bus resource [bus 80-84]
[ 0.421170] pci 0000:80:04.0: [8086:2021] type 00 class 0x088000
[ 0.421195] pci 0000:80:04.0: reg 0x10: [mem 0xd3ffff1c000-0xd3ffff1ffff 64bit]
[ 0.421355] pci 0000:80:04.1: [8086:2021] type 00 class 0x088000
[ 0.421382] pci 0000:80:04.1: reg 0x10: [mem 0xd3ffff18000-0xd3ffff1bfff 64bit]
[ 0.421546] pci 0000:80:04.2: [8086:2021] type 00 class 0x088000
[ 0.421572] pci 0000:80:04.2: reg 0x10: [mem 0xd3ffff14000-0xd3ffff17fff 64bit]
[ 0.421742] pci 0000:80:04.3: [8086:2021] type 00 class 0x088000
[ 0.421768] pci 0000:80:04.3: reg 0x10: [mem 0xd3ffff10000-0xd3ffff13fff 64bit]
[ 0.421930] pci 0000:80:04.4: [8086:2021] type 00 class 0x088000
[ 0.421956] pci 0000:80:04.4: reg 0x10: [mem 0xd3ffff0c000-0xd3ffff0ffff 64bit]
[ 0.422118] pci 0000:80:04.5: [8086:2021] type 00 class 0x088000
[ 0.422144] pci 0000:80:04.5: reg 0x10: [mem 0xd3ffff08000-0xd3ffff0bfff 64bit]
[ 0.422305] pci 0000:80:04.6: [8086:2021] type 00 class 0x088000
[ 0.422331] pci 0000:80:04.6: reg 0x10: [mem 0xd3ffff04000-0xd3ffff07fff 64bit]
[ 0.422496] pci 0000:80:04.7: [8086:2021] type 00 class 0x088000
[ 0.422522] pci 0000:80:04.7: reg 0x10: [mem 0xd3ffff00000-0xd3ffff03fff 64bit]
[ 0.422682] pci 0000:80:05.0: [8086:2024] type 00 class 0x088000
[ 0.422840] pci 0000:80:05.2: [8086:2025] type 00 class 0x088000
[ 0.423012] pci 0000:80:05.4: [8086:2026] type 00 class 0x080020
[ 0.423032] pci 0000:80:05.4: reg 0x10: [mem 0xeb000000-0xeb000fff]
[ 0.423201] pci 0000:80:08.0: [8086:2014] type 00 class 0x088000
[ 0.423340] pci 0000:80:08.1: [8086:2015] type 00 class 0x110100
[ 0.423463] pci 0000:80:08.2: [8086:2016] type 00 class 0x088000
[ 0.423636] pci_bus 0000:80: on NUMA node 1
[ 0.423713] ACPI: PCI Root Bridge [PC07] (domain 0000 [bus 85-ad])
[ 0.423737] acpi PNP0A08:05: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.424142] acpi PNP0A08:05: _OSC: platform does not support [AER]
[ 0.424508] acpi PNP0A08:05: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.424511] acpi PNP0A08:05: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.424714] PCI host bridge to bus 0000:85
[ 0.424719] pci_bus 0000:85: root bus resource [io 0xa000-0xbfff window]
[ 0.424723] pci_bus 0000:85: root bus resource [mem 0xef400000-0xf37fbfff window]
[ 0.424727] pci_bus 0000:85: root bus resource [mem 0xd4000000000-0xd7fffffffff window]
[ 0.424731] pci_bus 0000:85: root bus resource [bus 85-ad]
[ 0.424751] pci 0000:85:00.0: [8086:2030] type 01 class 0x060400
[ 0.424865] pci 0000:85:00.0: PME# supported from D0 D3hot D3cold
[ 0.425115] pci 0000:85:05.0: [8086:2034] type 00 class 0x088000
[ 0.425289] pci 0000:85:05.2: [8086:2035] type 00 class 0x088000
[ 0.425461] pci 0000:85:05.4: [8086:2036] type 00 class 0x080020
[ 0.425482] pci 0000:85:05.4: reg 0x10: [mem 0xf1000000-0xf1000fff]
[ 0.425665] pci 0000:85:08.0: [8086:208d] type 00 class 0x088000
[ 0.425801] pci 0000:85:08.1: [8086:208d] type 00 class 0x088000
[ 0.425932] pci 0000:85:08.2: [8086:208d] type 00 class 0x088000
[ 0.426061] pci 0000:85:08.3: [8086:208d] type 00 class 0x088000
[ 0.426191] pci 0000:85:08.4: [8086:208d] type 00 class 0x088000
[ 0.426322] pci 0000:85:08.5: [8086:208d] type 00 class 0x088000
[ 0.426452] pci 0000:85:08.6: [8086:208d] type 00 class 0x088000
[ 0.426584] pci 0000:85:08.7: [8086:208d] type 00 class 0x088000
[ 0.426714] pci 0000:85:09.0: [8086:208d] type 00 class 0x088000
[ 0.426846] pci 0000:85:09.1: [8086:208d] type 00 class 0x088000
[ 0.426989] pci 0000:85:0e.0: [8086:208e] type 00 class 0x088000
[ 0.427117] pci 0000:85:0e.1: [8086:208e] type 00 class 0x088000
[ 0.427246] pci 0000:85:0e.2: [8086:208e] type 00 class 0x088000
[ 0.427376] pci 0000:85:0e.3: [8086:208e] type 00 class 0x088000
[ 0.427506] pci 0000:85:0e.4: [8086:208e] type 00 class 0x088000
[ 0.427636] pci 0000:85:0e.5: [8086:208e] type 00 class 0x088000
[ 0.427766] pci 0000:85:0e.6: [8086:208e] type 00 class 0x088000
[ 0.427904] pci 0000:85:0e.7: [8086:208e] type 00 class 0x088000
[ 0.432038] pci 0000:85:0f.0: [8086:208e] type 00 class 0x088000
[ 0.432170] pci 0000:85:0f.1: [8086:208e] type 00 class 0x088000
[ 0.432330] pci 0000:85:1d.0: [8086:2054] type 00 class 0x088000
[ 0.432460] pci 0000:85:1d.1: [8086:2055] type 00 class 0x088000
[ 0.432590] pci 0000:85:1d.2: [8086:2056] type 00 class 0x088000
[ 0.432721] pci 0000:85:1d.3: [8086:2057] type 00 class 0x088000
[ 0.432859] pci 0000:85:1e.0: [8086:2080] type 00 class 0x088000
[ 0.432994] pci 0000:85:1e.1: [8086:2081] type 00 class 0x088000
[ 0.433125] pci 0000:85:1e.2: [8086:2082] type 00 class 0x088000
[ 0.433257] pci 0000:85:1e.3: [8086:2083] type 00 class 0x088000
[ 0.433390] pci 0000:85:1e.4: [8086:2084] type 00 class 0x088000
[ 0.433522] pci 0000:85:1e.5: [8086:2085] type 00 class 0x088000
[ 0.433654] pci 0000:85:1e.6: [8086:2086] type 00 class 0x088000
[ 0.434052] pci 0000:86:00.0: [10de:1bb3] type 00 class 0x030200
[ 0.434078] pci 0000:86:00.0: reg 0x10: [mem 0xf0000000-0xf0ffffff]
[ 0.434094] pci 0000:86:00.0: reg 0x14: [mem 0xd7fe0000000-0xd7fefffffff 64bit pref]
[ 0.434109] pci 0000:86:00.0: reg 0x1c: [mem 0xd7ff0000000-0xd7ff1ffffff 64bit pref]
[ 0.434337] pci 0000:85:00.0: PCI bridge to [bus 86]
[ 0.434345] pci 0000:85:00.0: bridge window [mem 0xf0000000-0xf0ffffff]
[ 0.434353] pci 0000:85:00.0: bridge window [mem 0xd7fe0000000-0xd7ff1ffffff 64bit pref]
[ 0.434370] pci_bus 0000:85: on NUMA node 1
[ 0.434509] ACPI: PCI Root Bridge [PC08] (domain 0000 [bus ae-d6])
[ 0.434533] acpi PNP0A08:06: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.434830] acpi PNP0A08:06: _OSC: platform does not support [AER]
[ 0.434971] acpi PNP0A08:06: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.434972] acpi PNP0A08:06: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.435056] PCI host bridge to bus 0000:ae
[ 0.435057] pci_bus 0000:ae: root bus resource [io 0xc000-0xdfff window]
[ 0.435059] pci_bus 0000:ae: root bus resource [mem 0xf3800000-0xf7bfbfff window]
[ 0.435061] pci_bus 0000:ae: root bus resource [mem 0xd8000000000-0xdbfffffffff window]
[ 0.435063] pci_bus 0000:ae: root bus resource [bus ae-d6]
[ 0.435072] pci 0000:ae:00.0: [8086:2030] type 01 class 0x060400
[ 0.435101] pci 0000:ae:00.0: enabling Extended Tags
[ 0.435135] pci 0000:ae:00.0: PME# supported from D0 D3hot D3cold
[ 0.435200] pci 0000:ae:05.0: [8086:2034] type 00 class 0x088000
[ 0.435282] pci 0000:ae:05.2: [8086:2035] type 00 class 0x088000
[ 0.435365] pci 0000:ae:05.4: [8086:2036] type 00 class 0x080020
[ 0.435375] pci 0000:ae:05.4: reg 0x10: [mem 0xf3800000-0xf3800fff]
[ 0.435460] pci 0000:ae:08.0: [8086:2066] type 00 class 0x088000
[ 0.435534] pci 0000:ae:09.0: [8086:2066] type 00 class 0x088000
[ 0.435607] pci 0000:ae:0a.0: [8086:2040] type 00 class 0x088000
[ 0.435683] pci 0000:ae:0a.1: [8086:2041] type 00 class 0x088000
[ 0.435756] pci 0000:ae:0a.2: [8086:2042] type 00 class 0x088000
[ 0.435829] pci 0000:ae:0a.3: [8086:2043] type 00 class 0x088000
[ 0.435900] pci 0000:ae:0a.4: [8086:2044] type 00 class 0x088000
[ 0.435972] pci 0000:ae:0a.5: [8086:2045] type 00 class 0x088000
[ 0.436043] pci 0000:ae:0a.6: [8086:2046] type 00 class 0x088000
[ 0.436115] pci 0000:ae:0a.7: [8086:2047] type 00 class 0x088000
[ 0.436189] pci 0000:ae:0b.0: [8086:2048] type 00 class 0x088000
[ 0.436261] pci 0000:ae:0b.1: [8086:2049] type 00 class 0x088000
[ 0.436333] pci 0000:ae:0b.2: [8086:204a] type 00 class 0x088000
[ 0.436407] pci 0000:ae:0b.3: [8086:204b] type 00 class 0x088000
[ 0.436488] pci 0000:ae:0c.0: [8086:2040] type 00 class 0x088000
[ 0.436562] pci 0000:ae:0c.1: [8086:2041] type 00 class 0x088000
[ 0.436637] pci 0000:ae:0c.2: [8086:2042] type 00 class 0x088000
[ 0.436713] pci 0000:ae:0c.3: [8086:2043] type 00 class 0x088000
[ 0.436785] pci 0000:ae:0c.4: [8086:2044] type 00 class 0x088000
[ 0.436858] pci 0000:ae:0c.5: [8086:2045] type 00 class 0x088000
[ 0.436934] pci 0000:ae:0c.6: [8086:2046] type 00 class 0x088000
[ 0.437009] pci 0000:ae:0c.7: [8086:2047] type 00 class 0x088000
[ 0.437082] pci 0000:ae:0d.0: [8086:2048] type 00 class 0x088000
[ 0.437155] pci 0000:ae:0d.1: [8086:2049] type 00 class 0x088000
[ 0.437230] pci 0000:ae:0d.2: [8086:204a] type 00 class 0x088000
[ 0.437304] pci 0000:ae:0d.3: [8086:204b] type 00 class 0x088000
[ 0.437423] pci 0000:ae:00.0: PCI bridge to [bus af]
[ 0.437435] pci_bus 0000:ae: on NUMA node 1
[ 0.437475] ACPI: PCI Root Bridge [PC09] (domain 0000 [bus d7-ff])
[ 0.437485] acpi PNP0A08:07: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.437641] acpi PNP0A08:07: _OSC: platform does not support [AER]
[ 0.437780] acpi PNP0A08:07: _OSC: OS now controls [PCIeHotplug PME PCIeCapability]
[ 0.437782] acpi PNP0A08:07: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.437866] PCI host bridge to bus 0000:d7
[ 0.437868] pci_bus 0000:d7: root bus resource [io 0xe000-0xffff window]
[ 0.437869] pci_bus 0000:d7: root bus resource [mem 0xf7c00000-0xfbffbfff window]
[ 0.437871] pci_bus 0000:d7: root bus resource [mem 0xdc000000000-0xdffffffffff window]
[ 0.437872] pci_bus 0000:d7: root bus resource [bus d7-ff]
[ 0.437882] pci 0000:d7:00.0: [8086:2030] type 01 class 0x060400
[ 0.437912] pci 0000:d7:00.0: enabling Extended Tags
[ 0.437949] pci 0000:d7:00.0: PME# supported from D0 D3hot D3cold
[ 0.438016] pci 0000:d7:05.0: [8086:2034] type 00 class 0x088000
[ 0.438101] pci 0000:d7:05.2: [8086:2035] type 00 class 0x088000
[ 0.438186] pci 0000:d7:05.4: [8086:2036] type 00 class 0x080020
[ 0.438197] pci 0000:d7:05.4: reg 0x10: [mem 0xf7c00000-0xf7c00fff]
[ 0.438289] pci 0000:d7:0e.0: [8086:2058] type 00 class 0x110100
[ 0.438360] pci 0000:d7:0e.1: [8086:2059] type 00 class 0x088000
[ 0.438435] pci 0000:d7:0f.0: [8086:2058] type 00 class 0x110100
[ 0.438509] pci 0000:d7:0f.1: [8086:2059] type 00 class 0x088000
[ 0.438585] pci 0000:d7:12.0: [8086:204c] type 00 class 0x110100
[ 0.438654] pci 0000:d7:12.1: [8086:204d] type 00 class 0x110100
[ 0.438713] pci 0000:d7:12.2: [8086:204e] type 00 class 0x088000
[ 0.438776] pci 0000:d7:15.0: [8086:2018] type 00 class 0x088000
[ 0.438836] pci 0000:d7:16.0: [8086:2018] type 00 class 0x088000
[ 0.438894] pci 0000:d7:16.4: [8086:2018] type 00 class 0x088000
[ 0.438986] pci 0000:d7:00.0: PCI bridge to [bus d8]
[ 0.438998] pci_bus 0000:d7: on NUMA node 1
[ 0.439455] SCSI subsystem initialized
[ 0.439517] libata version 3.00 loaded.
[ 0.439517] pci 0000:01:00.1: vgaarb: setting as boot VGA device
[ 0.439517] pci 0000:01:00.1: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.439517] pci 0000:01:00.1: vgaarb: bridge control possible
[ 0.439517] vgaarb: loaded
[ 0.439517] ACPI: bus type USB registered
[ 0.439517] usbcore: registered new interface driver usbfs
[ 0.439517] usbcore: registered new interface driver hub
[ 0.439517] usbcore: registered new device driver usb
[ 0.440060] EDAC MC: Ver: 3.0.0
[ 0.440355] Registered efivars operations
[ 0.456050] PCI: Using ACPI for IRQ routing
[ 0.459824] PCI: pci_cache_line_size set to 64 bytes
[ 0.460167] e820: reserve RAM buffer [mem 0x0008e000-0x0008ffff]
[ 0.460168] e820: reserve RAM buffer [mem 0x865e1000-0x87ffffff]
[ 0.460170] e820: reserve RAM buffer [mem 0x8f1e6000-0x8fffffff]
[ 0.460171] e820: reserve RAM buffer [mem 0x90201000-0x93ffffff]
[ 0.460172] e820: reserve RAM buffer [mem 0x90217000-0x93ffffff]
[ 0.460173] e820: reserve RAM buffer [mem 0x9a132000-0x9bffffff]
[ 0.460175] e820: reserve RAM buffer [mem 0x9d434000-0x9fffffff]
[ 0.460176] e820: reserve RAM buffer [mem 0xaf800000-0xafffffff]
[ 0.460177] e820: reserve RAM buffer [mem 0x103ffff000-0x103fffffff]
[ 0.460766] NetLabel: Initializing
[ 0.460767] NetLabel: domain hash size = 128
[ 0.460768] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.460785] NetLabel: unlabeled traffic allowed by default
[ 0.464406] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.464412] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.466547] clocksource: Switched to clocksource hpet
[ 0.476696] VFS: Disk quotas dquot_6.6.0
[ 0.476739] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.476925] AppArmor: AppArmor Filesystem Enabled
[ 0.476946] pnp: PnP ACPI init
[ 0.477370] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.477543] system 00:01: [io 0x0500-0x053f] has been reserved
[ 0.477544] system 00:01: [io 0x0400-0x047f] has been reserved
[ 0.477547] system 00:01: [io 0x0540-0x057f] has been reserved
[ 0.477548] system 00:01: [io 0x0600-0x061f] has been reserved
[ 0.477550] system 00:01: [io 0x0880-0x0883] has been reserved
[ 0.477552] system 00:01: [io 0x0800-0x081f] has been reserved
[ 0.477555] system 00:01: [mem 0xfed1c000-0xfed3ffff] has been reserved
[ 0.477557] system 00:01: [mem 0xfed45000-0xfed8bfff] has been reserved
[ 0.477562] system 00:01: [mem 0xff000000-0xffffffff] has been reserved
[ 0.477564] system 00:01: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.477565] system 00:01: [mem 0xfed12000-0xfed1200f] has been reserved
[ 0.477567] system 00:01: [mem 0xfed12010-0xfed1201f] has been reserved
[ 0.477569] system 00:01: [mem 0xfed1b000-0xfed1bfff] has been reserved
[ 0.477574] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.477599] pnp 00:02: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.477624] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.477770] pnp: PnP ACPI: found 4 devices
[ 0.484922] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.484956] pci 0000:00:1c.0: BAR 14: assigned [mem 0xd9c00000-0xd9cfffff]
[ 0.484961] pci 0000:02:00.0: BAR 6: assigned [mem 0xd9c00000-0xd9c3ffff pref]
[ 0.484964] pci 0000:02:00.1: BAR 6: assigned [mem 0xd9c40000-0xd9c7ffff pref]
[ 0.484966] pci 0000:02:00.2: BAR 6: assigned [mem 0xd9c80000-0xd9cbffff pref]
[ 0.484968] pci 0000:02:00.3: BAR 6: assigned [mem 0xd9cc0000-0xd9cfffff pref]
[ 0.484970] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.484974] pci 0000:00:1c.0: bridge window [mem 0xd9c00000-0xd9cfffff]
[ 0.484978] pci 0000:00:1c.0: bridge window [mem 0xd9d00000-0xd9dfffff 64bit pref]
[ 0.484983] pci 0000:01:00.2: BAR 6: assigned [mem 0xd0000000-0xd000ffff pref]
[ 0.484985] pci 0000:00:1c.4: PCI bridge to [bus 01]
[ 0.484987] pci 0000:00:1c.4: bridge window [io 0x1000-0x1fff]
[ 0.484991] pci 0000:00:1c.4: bridge window [mem 0xd0000000-0xd9bfffff]
[ 0.484998] pci_bus 0000:00: resource 4 [mem 0x000c4000-0x000cbfff window]
[ 0.485000] pci_bus 0000:00: resource 5 [io 0x0000-0x03af window]
[ 0.485002] pci_bus 0000:00: resource 6 [io 0x03e0-0x0cf7 window]
[ 0.485003] pci_bus 0000:00: resource 7 [io 0x03b0-0x03bb window]
[ 0.485004] pci_bus 0000:00: resource 8 [io 0x03c0-0x03df window]
[ 0.485006] pci_bus 0000:00: resource 9 [mem 0x000a0000-0x000bffff window]
[ 0.485007] pci_bus 0000:00: resource 10 [io 0x1000-0x3fff window]
[ 0.485009] pci_bus 0000:00: resource 11 [mem 0xd0000000-0xde3fbfff window]
[ 0.485011] pci_bus 0000:00: resource 12 [mem 0xc0000000000-0xc3fffffffff window]
[ 0.485012] pci_bus 0000:02: resource 1 [mem 0xd9c00000-0xd9cfffff]
[ 0.485014] pci_bus 00
