I have 4 Logitech webcams hooked up to my nano. Im running this:
deepstream-app -c source1_usb_dec_infer_resnet_int8.txt
I have tweeked it to run multiple web cams. I have webcams on Node=0, Node=1, node=2 and node=3.
I get and error when I try to run more than 2 webcams. Any combonation of 2 webcams works just fine. Its just when I try to run more than 2 I get this.
INFO: <bus_callback:149>: Pipeline running
ERROR from src_elem: Device '/dev/video1' is busy
Debug info: gstv4l2object.c(3754): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstV4l2Src:src_elem:
Call to S_FMT failed for YUYV @ 640x480: Device or resource busy
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstV4l2Src:src_elem:
streaming stopped, reason not-negotiated (-4)
Creating LL OSD context new
ERROR from src_elem: Failed to allocate required memory.
Debug info: gstv4l2src.c(658): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstV4l2Src:src_elem:
Buffer pool activation failed
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstV4l2Src:src_elem:
Quitting
App run failed
What is the best path forward to run multiple cameras. It doesn’t matter what kind?
Do you set batch-size=4 for 4 camera cases? Also source1_usb_dec_infer_resnet_int8.txt is for Xavier. Suggest you base on source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt for modification.
You may port [source*] from
to
source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt.
Copyright (c) 2018 NVIDIA Corporation. All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
# Following properties are mandatory when engine files are not specified:
# int8-calib-file(Only in INT8)
# Caffemodel mandatory properties: model-file, proto-file, output-blob-names
# UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
# ONNX: onnx-file
# Mandatory properties for detectors:
# num-detected-classes
# Optional properties for detectors:
# enable-dbscan(Default=false), interval(Primary mode only, Default=0)
# custom-lib-path,
# parse-bbox-func-name
# Mandatory properties for classifiers:
# classifier-threshold, is-classifier
# Optional properties for classifiers:
# classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
# operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
# input-object-min-width, input-object-min-height, input-object-max-width,
# input-object-max-height
# Following properties are always recommended:
# batch-size(Default=1)
# Other optional properties:
# net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
# model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
# mean-file, gie-unique-id(Default=0), offsets, gie-mode (Default=1 i.e. primary),
# custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../models/Primary_Detector_Nano/resnet10.caffemodel
proto-file=../../models/Primary_Detector_Nano/resnet10.prototxt
model-engine-file=../../models/Primary_Detector_Nano/resnet10.caffemodel_b8_fp16.engine
labelfile-path=../../models/Primary_Detector_Nano/labels.txt
batch-size=8
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
#parse-bbox-func-name=NvDsInferParseCustomResnet
#custom-lib-path=/path/to/libnvdsparsebbox.so
#enable-dbscan=1
[class-attrs-all]
threshold=0.2
group-threshold=1
## Set eps=0.7 and minBoxes for enable-dbscan=1
eps=0.2
#minBoxes=3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
## Per class configuration
#[class-attrs-2]
#threshold=0.6
#eps=0.5
#group-threshold=3
#roi-top-offset=20
#roi-bottom-offset=10
#detected-min-w=40
#detected-min-h=40
#detected-max-w=400
#detected-max-h=800
Hi all,
I’ve the same problem on Nano and Xavier devkit…
I’ve connected 4 different Logitech C270 USB cameras as (with v4l2 they’re present as /dev/video0-1-2-3).
With the following configuration file on Xavier I’m not able to run deepstream with more than 2 cameras at a time.
I modified the configuration file “source2_csi_usb_dec_infer_resnet_int8.txt” to add the USB camera needed (plus batch-size=4):
# Copyright (c) 2018 NVIDIA Corporation. All rights reserved.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=960
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=1
camera-width=640
camera-height=480
camera-fps-n=25
camera-fps-d=1
camera-v4l2-dev-node=0
[source1]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=25
camera-fps-d=1
camera-v4l2-dev-node=1
[source2]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=25
camera-fps-d=1
camera-v4l2-dev-node=2
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=5
sync=1
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=1
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
border-width=2
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[streammux]
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=4
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=640
height=480
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b4_int8.engine
#model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b30_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=2
#Required by the app for OSD, not a plugin property
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
config-file=config_infer_primary.txt
[tests]
file-loop=0
On Xavier, do you connect 4 USB cameras to the type-A port with a hub? There are two type-C ports on Xavier and you may try to connect USB cameras to the two ports.
We can run the following config on Jetson Nano/DS4.0.1:
[application]
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=960
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
[source1]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
[source2]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
[source3]
enable=1
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=3
[sink0]
enable=1
type=5
sync=0
display-id=0
offset-x=0
offset-y=0
width=0
height=0
overlay-id=1
source-id=0
[osd]
enable=1
border-width=2
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[streammux]
live-source=1
batch-size=4
width=640
height=480
[primary-gie]
enable=1
model-engine-file=../../models/Primary_Detector_Nano/resnet10.caffemodel_b4_fp16.engine
#property
batch-size=4
interval=4
gie-unique-id=1
config-file=config_infer_primary_nano.txt
[tests]
file-loop=0
We use the four USB cameras:
[two E-Con See3CAM_CU135]
I just downloaded the latest deepstream and installed on nano.
I tried 4 webcams and it still cant do more than 2 webcams.
I noticed that you are using"resnet10.caffemodel_b4_fp16.engine"
I can only find “resnet10.caffemodel_b8_fp16.engine” in …/…/models/Primary_Detector_Nano/ folder
Where is “resnet10.caffemodel_b4_fp16.engine” located or how is it generated?
I have duplicated the settings in your post.
[primary-gie]
enable=1
#property
batch-size=4
interval=4
gie-unique-id=1
The Jetson Nano development kit provides 4 x USB 3.0 to the outside. How can it have bandwidth limitations with this phalanx? In fact I’m unable to use more than 2 USB cameras.
