Deepstream5.0.1 dynamically adds cameras, but when a bad rtsp source is added, the pipeline will not be able to pull the stream
**• Hardware Platform (Jetson / GPU) TeslaT4
**• DeepStream Version 5.0.1
**• TensorRT Version 7.0.0
**• NVIDIA GPU Driver Version (valid for GPU only) 10.2
When I dynamically add a bad camera, the pipeline will be damaged, even if I dynamically delete the bad camera
What do you mean the pipeline damaged when dynamically add one bad rtsp camera, from the log, i did not see pipeline have issues?
Yes, when I add a bad rtsp source, all output fps becomes 0, even if I dynamically delete the bad rtsp source immediately after adding it ,I feel that the problem I encountered is the same as the link below ,but in the end it was not resolved
Releasing nvstreammux request pad blocked when input an invalid rtsp url - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
Did you use original dynamic add/delete samples or your own?
I refer to the official example in the link below
Can you repro the issue with original sample?
I will try
Any update?
