Deepstream6.2 配置sink插件通过rtsp输出url如何自定义
默认输出的rtsp路径为ds-test,如何配置成自定义的路径
文档里面只有配置端口的,没有配置路径的参数
could you use English? Thanks, the forum is public to the world.
• DeepStream Version
• TensorRT Version
how can i change the rtsp output url ?the default url is ds-test
deepstream-app is opensource. please refer the following code in \opt\nvidia\deepstream\deepstream\sources\apps\apps-common\src\deepstream_sink_bin.c
 gst_rtsp_mount_points_add_factory (mounts, "/ds-test", factory);
you can modify to other names. after modified, please rebuild the deepstream-app according to readme in /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app.
thank you
