DeepStream6.3 Error while setting IOCTL
**• Hardware Platform (GPU) RTX 3060
**• DeepStream Version 6.3
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only) CUDA12.0
• Issue Type (questions)
I’m using DeepStream 6.3 and running the following command:
./deepstream-app -c /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
but I’m encountering the following error:
WARNING from src_elem: No decoder available for type ‘audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2’.
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem
Invalid control
Invalid control
Invalid control
S_EXT_CTRLS for CUDA_GPU_ID failed
Invalid control
WARNING from src_elem: No decoder available for type ‘video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)high, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true’.
ERROR from src_elem: Your GStreamer installation is missing a plug-in.
Debug info: gsturidecodebin.c(987): no_more_pads_full (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem:
no suitable plugins found:
gstdecodebin2.c(4678): gst_decode_bin_expose (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3:
Missing decoder: MPEG-4 AAC (audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2)
Couldn’t set nvv4l2decoder0 to PAUSED
Debug info: gsturidecodebin.c(987): no_more_pads_full (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem:
gstdecodebin2.c(4678): gst_decode_bin_expose (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin1:
Couldn’t set nvv4l2decoder1 to PAUSED
Debug info: gsturidecodebin.c(987): no_more_pads_full (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem:
gstdecodebin2.c(4678): gst_decode_bin_expose (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0:
Couldn’t set nvv4l2decoder2 to PAUSED
ERROR from qtdemux3: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3/GstQTDemux:qtdemux3:
streaming stopped, reason not-linked (-1)
ERROR from qtdemux2: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux2:
ERROR from qtdemux1: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin1/GstQTDemux:qtdemux1:
Debug info: gsturidecodebin.c(987): no_more_pads_full (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem:
gstdecodebin2.c(4678): gst_decode_bin_expose (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin2:
Couldn’t set nvv4l2decoder3 to PAUSED
ERROR from qtdemux0: Internal data stream error.
Debug info: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin2/GstQTDemux:qtdemux0:
Quitting
May I ask what the problem is, and how to solve it?
Looks seem miss some elements of decoder.
Notice your cuda version is 12.0,DeepStream use the version 12.1
I think you can try reinstall the deepstream by this reference
I have already installed CUDA version 12.1 and reinstalled DeepStream 6.3, but I am still getting the same error message
1.try to remove cache files
rm ${HOME}/.cache/gstreamer-1.0/registry.x86_64.bin
2.Can the following command line be executed normally? If not, maybe the driver has not been installed successfully
gst-launch-1.0 uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264 ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! filesink location=out.h264
(gst-plugin-scanner:14163): GStreamer-WARNING **: 16:12:12.473: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvpx.so’: libvpx.so.6: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14163): GStreamer-WARNING **: 16:12:12.497: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14163): GStreamer-WARNING **: 16:12:12.500: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstlibav.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14163): GStreamer-WARNING **: 16:12:12.933: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14163): GStreamer-WARNING **: 16:12:13.002: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so’: libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14163): GStreamer-WARNING **: 16:12:13.014: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so’: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14163): GStreamer-WARNING **: 16:12:13.051: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so’: libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:14163): GStreamer-WARNING **: 16:12:13.102: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so’: libmpg123.so.0: cannot open shared object file: No such file or directory
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
Invalid control
Missing element: H.264 (High Profile) decoder
WARNING: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: No decoder available for type ‘video/x-h264, width=(int)1280, height=(int)720, framerate=(fraction)30/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)high, level=(string)3.1’.
Additional debug info:
gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0
ERROR: from element /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0: Your GStreamer installation is missing a plug-in.
gsturidecodebin.c(987): no_more_pads_full (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0:
gstdecodebin2.c(4678): gst_decode_bin_expose (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin0/GstDecodeBin:decodebin0:
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to NULL …
Freeing pipeline …
But I checked, and these folders and files are present.
When executed again, the following error occurs:
Invalid control
Freeing pipeline …
cd /opt/nvidia/deepstream/deepstream
./user_additional_install.sh
./install.sh
After following the instructions, there will be the following error, but the program can be executed successfully and the interface is displayed.
(gst-plugin-scanner:35845): GStreamer-WARNING **: 16:29:14.639: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
0:00:02.801248774 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 6]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:02.854947867 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 6]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:02.857315852 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_2> [UID 6]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_secondary_carmake.txt sucessfully
0:00:04.146942325 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 5]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:04.201379526 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 5]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:04.202771055 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
0:00:05.497791078 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 4]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:05.555474405 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 4]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:05.556761381 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:06.880070856 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:06.937052442 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
0:00:06.938006330 35844 0x7fe2a00022a0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
    p: Pause
    r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:239>: Pipeline ready
Invalid control
Invalid control
Invalid control
Invalid control
** INFO: <bus_callback:225>: Pipeline running
**PERF: 48.16 (48.00) 48.16 (48.00) 48.16 (48.00) 48.16 (48.00)
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
[NvMultiObjectTracker] De-initialized
App run successful
This is error from GPU driver.
I think you had better check if the driver is installed normally.
