I tried to use custom yolov3-tiny inside deepstream sdk 4.0.1 , but it raised number of classes error.
I did change the number of classes in nvdsparsebbox_Yolo.cpp, it still failed.
error message
JetsonNano:~/deepstream/sources/objectDetector_Yolo$ deepstream-app -c deepstream_app_config_yoloV3_tiny_test1.txt
Using winsys: x11
Creating LL OSD context new
0:00:03.286178283 10134 0x7f1c002240 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
Loading pre-trained weights...
Loading complete!
Total Number of weights read : 8680864
layer inp_size out_size weightPtr
(1) conv-bn-leaky 3 x 416 x 416 16 x 416 x 416 496
(2) maxpool 16 x 416 x 416 16 x 208 x 208 496
(3) conv-bn-leaky 16 x 208 x 208 32 x 208 x 208 5232
(4) maxpool 32 x 208 x 208 32 x 104 x 104 5232
(5) conv-bn-leaky 32 x 104 x 104 64 x 104 x 104 23920
(6) maxpool 64 x 104 x 104 64 x 52 x 52 23920
(7) conv-bn-leaky 64 x 52 x 52 128 x 52 x 52 98160
(8) maxpool 128 x 52 x 52 128 x 26 x 26 98160
(9) conv-bn-leaky 128 x 26 x 26 256 x 26 x 26 394096
(10) maxpool 256 x 26 x 26 256 x 13 x 13 394096
(11) conv-bn-leaky 256 x 13 x 13 512 x 13 x 13 1575792
(12) maxpool 512 x 13 x 13 512 x 13 x 13 1575792
(13) conv-bn-leaky 512 x 13 x 13 1024 x 13 x 13 6298480
(14) conv-bn-leaky 1024 x 13 x 13 256 x 13 x 13 6561648
(15) conv-bn-leaky 256 x 13 x 13 512 x 13 x 13 7743344
(16) conv-linear 512 x 13 x 13 24 x 13 x 13 7755656
(17) yolo 24 x 13 x 13 24 x 13 x 13 7755656
(18) route - 256 x 13 x 13 7755656
(19) conv-bn-leaky 256 x 13 x 13 128 x 13 x 13 7788936
(20) upsample 128 x 13 x 13 128 x 26 x 26 -
(21) route - 384 x 26 x 26 7788936
(22) conv-bn-leaky 384 x 26 x 26 256 x 26 x 26 8674696
(23) conv-linear 256 x 26 x 26 24 x 26 x 26 8680864
(24) yolo 24 x 26 x 26 24 x 26 x 26 8680864
Output blob names :
yolo_17
yolo_24
Total number of layers: 50
Total number of layers on DLA: 0
Building the TensorRT Engine...
Building complete!
0:01:11.397682548 10134 0x7f1c002240 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/nanoubi/deepstream/sources/objectDetector_Yolo/model_b1_fp32.engine
Deserialize yoloLayerV3 plugin: yolo_17
Deserialize yoloLayerV3 plugin: yolo_24
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:175>: Pipeline running
WARNING: Num classes mismatch. Configured:3, detected by network: 80
* Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include "nvdsinfer_custom_impl.h"
#include <algorithm>
#include <cassert>
#include <cmath>
#include <cstring>
#include <fstream>
#include <iostream>
#include <unordered_map>
static const int NUM_CLASSES_YOLO = 3;
extern "C" bool NvDsInferParseCustomYoloV3(
std::vector<NvDsInferLayerInfo> const& outputLayersInfo,
NvDsInferNetworkInfo const& networkInfo,
NvDsInferParseDetectionParams const& detectionParams,
std::vector<NvDsInferParseObjectInfo>& objectList);
extern "C" bool NvDsInferParseCustomYoloV3Tiny(
extern "C" bool NvDsInferParseCustomYoloV2(
extern "C" bool NvDsInferParseCustomYoloV2Tiny(
static unsigned clamp(const uint val, const uint minVal, const uint maxVal)
assert(minVal <= maxVal);
return std::min(maxVal, std::max(minVal, val));
/* This is a sample bounding box parsing function for the sample YoloV3 detector model */
static NvDsInferParseObjectInfo convertBBox(const float& bx, const float& by, const float& bw,
const float& bh, const int& stride, const uint& netW,
const uint& netH)
NvDsInferParseObjectInfo b;
// Restore coordinates to network input resolution
float x = bx * stride;
float y = by * stride;
b.left = x - bw / 2;
b.width = bw;
b.top = y - bh / 2;
b.height = bh;
b.left = clamp(b.left, 0, netW);
b.width = clamp(b.width, 0, netW);
b.top = clamp(b.top, 0, netH);
b.height = clamp(b.height, 0, netH);
return b;
static void addBBoxProposal(const float bx, const float by, const float bw, const float bh,
const uint stride, const uint& netW, const uint& netH, const int maxIndex,
const float maxProb, std::vector<NvDsInferParseObjectInfo>& binfo)
NvDsInferParseObjectInfo bbi = convertBBox(bx, by, bw, bh, stride, netW, netH);
if (((bbi.left + bbi.width) > netW) || ((bbi.top + bbi.height) > netH)) return;
bbi.detectionConfidence = maxProb;
bbi.classId = maxIndex;
binfo.push_back(bbi);
static std::vector<NvDsInferParseObjectInfo>
nonMaximumSuppression(const float nmsThresh, std::vector<NvDsInferParseObjectInfo> binfo)
auto overlap1D = [](float x1min, float x1max, float x2min, float x2max) -> float {
if (x1min > x2min)
std::swap(x1min, x2min);
std::swap(x1max, x2max);
return x1max < x2min ? 0 : std::min(x1max, x2max) - x2min;
auto computeIoU
= [&overlap1D](NvDsInferParseObjectInfo& bbox1, NvDsInferParseObjectInfo& bbox2) -> float {
float overlapX
= overlap1D(bbox1.left, bbox1.left + bbox1.width, bbox2.left, bbox2.left + bbox2.width);
float overlapY
= overlap1D(bbox1.top, bbox1.top + bbox1.height, bbox2.top, bbox2.top + bbox2.height);
float area1 = (bbox1.width) * (bbox1.height);
float area2 = (bbox2.width) * (bbox2.height);
float overlap2D = overlapX * overlapY;
float u = area1 + area2 - overlap2D;
return u == 0 ? 0 : overlap2D / u;
std::stable_sort(binfo.begin(), binfo.end(),
[](const NvDsInferParseObjectInfo& b1, const NvDsInferParseObjectInfo& b2) {
return b1.detectionConfidence > b2.detectionConfidence;
std::vector<NvDsInferParseObjectInfo> out;
for (auto i : binfo)
bool keep = true;
for (auto j : out)
if (keep)
float overlap = computeIoU(i, j);
keep = overlap <= nmsThresh;
else
break;
if (keep) out.push_back(i);
return out;
nmsAllClasses(const float nmsThresh,
std::vector<NvDsInferParseObjectInfo>& binfo,
const uint numClasses)
std::vector<NvDsInferParseObjectInfo> result;
std::vector<std::vector<NvDsInferParseObjectInfo>> splitBoxes(numClasses);
for (auto& box : binfo)
splitBoxes.at(box.classId).push_back(box);
for (auto& boxes : splitBoxes)
boxes = nonMaximumSuppression(nmsThresh, boxes);
result.insert(result.end(), boxes.begin(), boxes.end());
return result;
decodeYoloV2Tensor(
const float* detections, const std::vector<float> &anchors,
const uint gridSize, const uint stride, const uint numBBoxes,
const uint numOutputClasses, const float probThresh, const uint& netW,
const uint& netH)
std::vector<NvDsInferParseObjectInfo> binfo;
for (uint y = 0; y < gridSize; ++y)
for (uint x = 0; x < gridSize; ++x)
for (uint b = 0; b < numBBoxes; ++b)
const float pw = anchors[b * 2];
const float ph = anchors[b * 2 + 1];
const int numGridCells = gridSize * gridSize;
const int bbindex = y * gridSize + x;
const float bx
= x + detections[bbindex + numGridCells * (b * (5 + numOutputClasses) + 0)];
const float by
= y + detections[bbindex + numGridCells * (b * (5 + numOutputClasses) + 1)];
const float bw
= pw * exp (detections[bbindex + numGridCells * (b * (5 + numOutputClasses) + 2)]);
const float bh
= ph * exp (detections[bbindex + numGridCells * (b * (5 + numOutputClasses) + 3)]);
const float objectness
= detections[bbindex + numGridCells * (b * (5 + numOutputClasses) + 4)];
float maxProb = 0.0f;
int maxIndex = -1;
for (uint i = 0; i < numOutputClasses; ++i)
float prob
= (detections[bbindex
+ numGridCells * (b * (5 + numOutputClasses) + (5 + i))]);
if (prob > maxProb)
maxProb = prob;
maxIndex = i;
maxProb = objectness * maxProb;
if (maxProb > probThresh)
addBBoxProposal(bx, by, bw, bh, stride, netW, netH, maxIndex, maxProb, binfo);
return binfo;
decodeYoloV3Tensor(
const float* detections, const std::vector<int> &mask, const std::vector<float> &anchors,
const uint& netH)
const float pw = anchors[mask[b] * 2];
const float ph = anchors[mask[b] * 2 + 1];
const float bx
const float by
const float bw
= pw * detections[bbindex + numGridCells * (b * (5 + numOutputClasses) + 2)];
const float bh
= ph * detections[bbindex + numGridCells * (b * (5 + numOutputClasses) + 3)];
int maxIndex = -1;
float prob
if (prob > maxProb)
maxProb = prob;
maxIndex = i;
return binfo;
static inline std::vector<const NvDsInferLayerInfo*>
SortLayers(const std::vector<NvDsInferLayerInfo> & outputLayersInfo)
std::vector<const NvDsInferLayerInfo*> outLayers;
for (auto const &layer : outputLayersInfo) {
outLayers.push_back (&layer);
std::sort (outLayers.begin(), outLayers.end(),
[](const NvDsInferLayerInfo *a, const NvDsInferLayerInfo *b){
return a->dims.d[1] < b->dims.d[1];
return outLayers;
static bool NvDsInferParseYoloV3(
std::vector<NvDsInferParseObjectInfo>& objectList,
const std::vector<std::vector<int>> &masks)
const uint kNUM_BBOXES = 3;
static const float kNMS_THRESH = 0.5f;
static const float kPROB_THRESH = 0.7f;
const std::vector<const NvDsInferLayerInfo*> sortedLayers =
SortLayers (outputLayersInfo);
if (sortedLayers.size() != masks.size()) {
std::cerr << "ERROR: yoloV3 output layer.size: " << sortedLayers.size()
<< " does not match mask.size: " << masks.size() << std::endl;
return false;
if (NUM_CLASSES_YOLO != detectionParams.numClassesConfigured)
std::cerr << "WARNING: Num classes mismatch. Configured:"
<< detectionParams.numClassesConfigured
<< ", detected by network: " << NUM_CLASSES_YOLO << std::endl;
std::vector<NvDsInferParseObjectInfo> objects;
for (uint idx = 0; idx < masks.size(); ++idx) {
const NvDsInferLayerInfo &layer = *sortedLayers[idx]; // 255 x Grid x Grid
assert (layer.dims.numDims == 3);
const uint gridSize = layer.dims.d[1];
const uint stride = networkInfo.width / gridSize;
std::vector<NvDsInferParseObjectInfo> outObjs =
decodeYoloV3Tensor((const float*)(layer.buffer), masks[idx], anchors, gridSize, stride, kNUM_BBOXES,
NUM_CLASSES_YOLO, kPROB_THRESH, networkInfo.width, networkInfo.height);
objects.insert(objects.end(), outObjs.begin(), outObjs.end());
objectList.clear();
objectList = nmsAllClasses(kNMS_THRESH, objects, NUM_CLASSES_YOLO);
return true;
/* C-linkage to prevent name-mangling */
static const std::vector<float> kANCHORS = {
10.0, 13.0, 16.0, 30.0, 33.0, 23.0, 30.0, 61.0, 62.0,
45.0, 59.0, 119.0, 116.0, 90.0, 156.0, 198.0, 373.0, 326.0};
static const std::vector<std::vector<int>> kMASKS = {
{6, 7, 8},
{3, 4, 5},
{0, 1, 2}};
return NvDsInferParseYoloV3 (
outputLayersInfo, networkInfo, detectionParams, objectList,
kANCHORS, kMASKS);
10, 14, 23, 27, 37, 58, 81, 82, 135, 169, 344, 319};
{3, 4, 5},
//{0, 1, 2}}; // as per output result, select {1,2,3}
{1, 2, 3}};
kANCHORS, kMASKS);
static bool NvDsInferParseYoloV2(
const float nmsThreshold, const float probthreshold)
18.3273602, 21.6763191, 59.9827194, 66.0009613,
106.829758, 175.178879, 252.250244, 112.888962,
312.656647, 293.384949 };
const uint kNUM_BBOXES = 5;
if (outputLayersInfo.empty()) {
std::cerr << "Could not find output layer in bbox parsing" << std::endl;;
return false;
const NvDsInferLayerInfo &layer = outputLayersInfo[0];
std::vector<NvDsInferParseObjectInfo> objects =
decodeYoloV2Tensor((const float*)(layer.buffer), kANCHORS, gridSize, stride, kNUM_BBOXES,
NUM_CLASSES_YOLO, probthreshold, networkInfo.width, networkInfo.height);
objectList.clear();
objectList = nmsAllClasses(nmsThreshold, objects, NUM_CLASSES_YOLO);
return true;
static const float kNMS_THRESH = 0.3f;
static const float kPROB_THRESH = 0.6f;
return NvDsInferParseYoloV2 (
kNMS_THRESH, kPROB_THRESH);
static const float kNMS_THRESH = 0.2f;
/* Check that the custom function has been defined correctly */
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomYoloV3);
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomYoloV3Tiny);
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomYoloV2);
CHECK_CUSTOM_PARSE_FUNC_PROTOTYPE(NvDsInferParseCustomYoloV2Tiny);
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://test1/1_cut.mp4
num-sources=1
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=model_b1_fp32.engine
labelfile-path=test1/labels.names
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3_tiny_test1.txt
[tests]
file-loop=0
# Following properties are mandatory when engine files are not specified:
# int8-calib-file(Only in INT8), model-file-format
# Caffemodel mandatory properties: model-file, proto-file, output-blob-names
# UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
# ONNX: onnx-file
# Mandatory properties for detectors:
# num-detected-classes
# Optional properties for detectors:
# enable-dbscan(Default=false), interval(Primary mode only, Default=0)
# custom-lib-path
# parse-bbox-func-name
# Mandatory properties for classifiers:
# classifier-threshold, is-classifier
# Optional properties for classifiers:
# classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
# operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
# input-object-min-width, input-object-min-height, input-object-max-width,
# input-object-max-height
# Following properties are always recommended:
# batch-size(Default=1)
# Other optional properties:
# net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
# model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
# mean-file, gie-unique-id(Default=0), offsets, gie-mode (Default=1 i.e. primary),
# custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
[property]
gpu-id=0
net-scale-factor=1
#0=RGB, 1=BGR
model-color-format=0
custom-network-config=test1/yolov3-tiny_obj.cfg
model-file=test1/yolov3-tiny_obj_50000.weights
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=3
gie-unique-id=1
is-classifier=0
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseCustomYoloV3Tiny
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
