could you share more logs? please do “export GST_DEBUG=6” first to modify Gstreamer’s log level, then run again, you can redirect the logs to a file.
0:00:01.670889064 e[335m10060e[00m 0x56289b733240 e[31;01mERROR e[00m e[00m v4l2bufferpool gstv4l2bufferpool.c:161:gst_v4l2_buffer_pool_copy_buffer:<src_elem:pool:src>e[00m could not map buffer
from the key log in log_error.txt, it is gstramer low level error.
noticing you have ever run successfully the deestream-app, what is the difference? the working test is on Geforce GTX 1050, the current test is on T4?
