Hello. I’m having a lot of fun with Omniverse! Everything that I tested so far worked really well.
The only thing I couldn’t find for now in docs or reading the source code what’s the address you need to make a request to when you’re using omni.services.core
. I tried:
- localhost:[8080,3009,3010,8000]
- omniverse://localhost…
But none of them work.
In an extension on_startup
from omni.services.core import main
async def get_stage():
uri = omni.usd.get_context().get_stage_url()
return {"file_uri": uri}
main.register_endpoint("get", "/stage", get_stage)
And making the request from Creator’s script editor:
omni.kit.pipapi.install("requests")
import requests
s = requests.Session()
r = s.get("http://localhost:3080/stage")
print(r.text)
I have the same problem with omni.services.usd
I’m using the default installation. Cache/Web/System Monitor/Connection from a different PC, everything works fine.
This is probably a simple answer, thanks.
