我修改了kernel的defconfig文件,然后重新编译内核和模块,烧录之后initrd启动失败,日志如下:
[ 3.340024] Freeing unused kernel memory: 7616K
[ 3.340095] Run /init as init process
[ 3.355024] Checking overlayfs setting...
[ 3.363580] Overlayfs is disabled...
[ 3.369287] Root device found: PARTUUID=3c94872b-6070-4e9f-9480-070e3296a897
[ 3.619520] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 3.776342] hub 1-2:1.0: USB hub found
[ 3.777174] hub 1-2:1.0: 4 ports detected
[ 3.907359] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[ 4.064988] hub 1-3:1.0: USB hub found
[ 4.065796] hub 1-3:1.0: 4 ports detected
[ 4.359519] usb 1-3.1: new high-speed USB device number 4 using tegra-xusb
[ 4.579518] usb 1-3.2: new full-speed USB device number 5 using tegra-xusb
[ 6.656873] pcie_tegra194: module verification failed: signature and/or required key missing - tainting kernel
[ 6.657002] pcie_tegra194: disagrees about version of symbol _dev_info
[ 6.657004] pcie_tegra194: Unknown symbol _dev_info (err -22)
[ 6.657015] pcie_tegra194: disagrees about version of symbol _dev_err
[ 6.657016] pcie_tegra194: Unknown symbol _dev_err (err -22)
[ 6.657030] pcie_tegra194: disagrees about version of symbol _dev_warn
[ 6.657031] pcie_tegra194: Unknown symbol _dev_warn (err -22)
[ 6.657066] pcie_tegra194: disagrees about version of symbol dev_err_probe
[ 6.657067] pcie_tegra194: Unknown symbol dev_err_probe (err -22)
[ 6.657073] pcie_tegra194: disagrees about version of symbol _dev_printk
[ 6.657073] pcie_tegra194: Unknown symbol _dev_printk (err -22)
[ 6.677282] phy_tegra194_p2u: disagrees about version of symbol _dev_err
[ 6.677287] phy_tegra194_p2u: Unknown symbol _dev_err (err -22)
[ 6.677293] phy_tegra194_p2u: disagrees about version of symbol _dev_warn
[ 6.677294] phy_tegra194_p2u: Unknown symbol _dev_warn (err -22)
[ 6.702021] nvme_core: disagrees about version of symbol device_remove_file_self
[ 6.702025] nvme_core: Unknown symbol device_remove_file_self (err -22)
[ 6.702036] nvme_core: disagrees about version of symbol dev_set_name
[ 6.702038] nvme_core: Unknown symbol dev_set_name (err -22)
[ 6.702065] nvme_core: disagrees about version of symbol device_initialize
[ 6.702066] nvme_core: Unknown symbol device_initialize (err -22)
[ 6.702091] nvme_core: disagrees about version of symbol bpf_trace_run2
[ 6.702092] nvme_core: Unknown symbol bpf_trace_run2 (err -22)
可能是新生成的内核模块没有打包到initrd中,请问如果重新打包initrd
