Defective onboard RTL8127 NIC on DGX Spark
My DGX Spark’s onboard Realtek RTL8127 Ethernet NIC (r8127 driver
11.014.00-NAPI) has persistent, intermittent packet loss and link
instability that I have been unable to resolve through software. I
believe this is a hardware defect and would like to request an
RMA/replacement.
Symptoms
  • Bursty packet loss up to ~21% to the local gateway (confirmed via ping).
  • Link flaps — observed the link go fully down for ~12 minutes
    (r8127: enP7s7: link down → link up), and it continues to flap even
    after a fresh OS update (see logs below, link down at 11:23 today).
  • rx_errors counter accumulating continuously (1,180,000+ on the previous
    boot; already 140,000+ within one hour on the current boot).
  • ethtool reports the link negotiated at 1000 Mb/s while the PHY
    advertises ONLY 10baseT — an abnormal, inconsistent state.
Proof it is this unit, not my network
I run FOUR identical DGX Spark units on the same switch/gateway. The
other three show ~0.00% packet loss over a 13-hour overnight ping; THIS
unit alone shows 9-21% loss under identical conditions. (Screenshot
attached: three machines pinging the same gateway 192.168.0.1 — a086 and
0077 at ~0.00%, da01 at 9.03% loss.)
Everything I have already tried (problem persists after each)
  1. Disabled Energy Efficient Ethernet (EEE) — the documented NVIDIA
    workaround.
  2. Replaced the cable with a brand-new CAT6.
  3. Updated DGX OS to the latest (OTA 7.5.0, kernel 6.17.0-1029-nvidia) —
    NIC driver unchanged, issue unchanged.
  4. Disabled all NIC offloads and flow control (ethtool -K / -A) — only
    briefly helped, loss returns.
  5. Ruled out any software/intrusion cause (clean process and connection
    audit).
Since EEE-off, a new cable, an OS update, and offload changes all fail to
fix it, and three identical units on the same network are perfectly
stable, this points to a hardware fault in the onboard RTL8127 NIC of
this specific unit.
Serial number: 1983725002404
Please advise on the RMA process. Full ethtool and kernel-log dumps are
included below.
Thank you.
TECHNICAL EVIDENCE (attach / paste as needed)
[System]
DGX OS OTA version : 7.5.0 (was 7.3.1 before update; issue predates and
survives the update)
SW build : 7.2.3
Kernel : 6.17.0-1029-nvidia
NIC driver : r8127 11.014.00-NAPI
Serial number : 1983725002404
Interface : enP7s7 (192.168.0.35)
[ethtool enP7s7 — abnormal link negotiation]
Advertised link modes : 10baseT/Half 10baseT/Full ← abnormal
Link partner advertised : 10baseT/Half 10baseT/Full
Speed : 1000Mb/s ← inconsistent
Duplex : Full
Link detected : yes
[ethtool -S enP7s7 — error counters, current boot ~1h uptime]
rx_errors : 140356 (was 1,180,000+ on previous boot)
rx_mac_missed : 7138
rx_pause_on : 336
rx_pause_off : 333
[Kernel log — link flapping, STILL occurring after 7.5.0 update]
Jul 28 11:23:41 spark-da01 kernel: r8127: enP7s7: link up
Jul 28 11:23:41 spark-da01 kernel: r8127: enP7s7: link down
Jul 28 11:23:44 spark-da01 kernel: r8127: enP7s7: link up
(earlier boot: 12-minute outage 10:10:48 → 10:22:53)
[Overnight ping comparison — same gateway 192.168.0.1, ~13.7 h]
spark-a086 : 48603 sent, 48599 recv, 0.0082% loss
spark-0077 : 48763 sent, 48761 recv, 0.0041% loss
spark-da01 : 48318 sent, 43953 recv, 9.0339% loss ← THIS UNIT
Sounds like a hardware issue. Just RMA it.
Thanks so much for providing useful technical background. While the networking information is helpful evidence, the RMA process specifically requires running the field diagnostics toolset (Docs: https://docs.nvidia.com/pdf/userguide-dgx-spark-fieldiag.pdf ). This will help narrow down whether this networking issue is hardware related or if there’s a potential software bug in play.
Thanks,
Zeke
Do I just return my DGX spark, the 1st day the GbE was unstable, after a couple of days It was working. Now it is not working again, I tried rebooting, and waiting, and that didn’t work. Changed cables, purchased better brands, I thought it was resolved. Now the issue reappeared. Check it out modinfo r8127 | grep version
version: 11.014.00-NAPI
srcversion: B8CE8DB6A21E011635749E6
vermagic: 6.17.0-1029-nvidia SMP preempt mod_unload modversions aarch64
ping 192.168.1.10
PING 192.168.1.10 (192.168.1.10) 56(84) bytes of data.
64 bytes from 192.168.1.10: icmp_seq=1 ttl=64 time=1.24 ms
64 bytes from 192.168.1.10: icmp_seq=3 ttl=64 time=1.20 ms
64 bytes from 192.168.1.10: icmp_seq=6 ttl=64 time=0.990 ms
64 bytes from 192.168.1.10: icmp_seq=7 ttl=64 time=1.05 ms
64 bytes from 192.168.1.10: icmp_seq=8 ttl=64 time=1.05 ms
64 bytes from 192.168.1.10: icmp_seq=9 ttl=64 time=1.07 ms
64 bytes from 192.168.1.10: icmp_seq=10 ttl=64 time=0.616 ms
64 bytes from 192.168.1.10: icmp_seq=12 ttl=64 time=1.06 ms
64 bytes from 192.168.1.10: icmp_seq=13 ttl=64 time=1.05 ms
64 bytes from 192.168.1.10: icmp_seq=16 ttl=64 time=1.04 ms
^C
-– 192.168.1.10 ping statistics —
16 packets transmitted, 10 received, 37.5% packet loss, time 15230ms
rtt min/avg/max/mdev = 0.616/1.035/1.237/0.157 ms
I just had my agent solve an ethernet issue for me and it believes you may want to read my post about it. The rest of this message is from my agent, reviewed by me.
Generated through agentic engineering with Claude Opus 5.5.
Before RMA: on my Spark, the same r8127 11.014.00 driver caused link failures that went away on the in-kernel r8169 driver. It wasn’t hardware. Details and an important warm-reboot caveat:
