Is there a way, using the runtime api? If so, can you point me to an example.
Thank you
Thank you
cudaSetDevice ?
cudaSetDevice() function may be what you are looking for.
Thanks. Is memory shared across device; i.e. what happens if I do
cudaSetDevice(0);
cudaMalloc(d_a, 1024*sizeof(int));
cudaSetDevice(1);
kernel<<<gridDim,blockDim>>>(d_a);
thanks
CUDA will probably generate an error. Once the device is set for a context, you cannot change it.
