Degenerate logits at temperature > 0: single CJK characters randomly spliced into English output (2× DGX Spark, GB10)
Environment
- Hardware: 2× NVIDIA DGX Spark (GB10, sm_121, 128GB unified memory), TP=2 across nodes via 200GbE RoCE direct connect
- Engine: vLLM 0.25.2 (image
ghcr.io/anemll/dspark-vllm-gx10:0.1.1, digest-verified) - Model: DeepSeek-V4-Flash-Vision-Exp, official FP8 weights (48 shards)
- Key params: DSpark speculative decoding (MTP=6),
--moe-backend flashinfer_b12x,--kv-cache-dtype nvfp4_ds_mla,
--max-model-len 1048576,--max-num-seqs 6,--async-scheduling, prefix caching on
Problem
At any temperature > 0, English output sporadically contains a single CJK character
spliced into words (e.g. compile玄, verify纲). The inserted token’s logprob equals
-ln(vocab) ≈ -11.77, i.e. the logits at that position are degenerate (uniform/uninitialized).
- temp = 0: completely clean (0/85 samples) — argmax masks the degenerate logits
- temp = 0.2–0.7: intermittent; ~0.8% on short prompts, up to 3–8 out of 10 responses
on long agent-style prompts (hundreds of rules + code analysis)
Already ruled out (controlled experiments)
- Speculative decoding (disabled → still reproduces)
- Temperature scaling path (temp 1.0 → worse, 8/10)
- Engine version (also reproduces on an older vLLM 0.21.1-based build)
- sparse-SWA RoPE fix (vllm#54815) → no effect
Suspect
Model forward/logits path correctness bug specific to GB10 (sm_121) — not a sampling
parameter issue. Workaround: force temperature 0 (deterministic output; reasoning via
reasoning_effort still works normally).
