I am seeing the same. My scripts that work fine on 4.1 and crashes on 4.2 with memory errors. The crash happens in the window app, not in the headless docker container. I will be running in headless docker extensively to confirm if it is fine. I am running replicator workflows.
[10.754s] app ready
[11.415s] Isaac Sim App is loaded.
2024-09-24 13:30:15 [43,228ms] [Warning] [omni.usd] Unexpected reference count of 2 for UsdStage 'anon:0x1ab9c2c0:World0.usd' while being closed in UsdContext (this may indicate it is still resident in memory).
2024-09-24 13:31:17 [105,944ms] [Warning] [omni.syntheticdata.plugin] OgnSdPostRenderVarToHost : rendervar copy from texture directly to host buffer is counter-performant. Please use copy from texture to device buffer first.
2024-09-24 13:31:22 [110,479ms] [Error] [carb.cudainterop.plugin] dup failed for resourceType: 3 (file descriptor: 1023)
Too many open files (error: 24)
2024-09-24 13:31:22 [110,479ms] [Error] [gpu.foundation.plugin] Cannot create cuda external memory for resource!
2024-09-24 13:31:22 [110,479ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,479ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,479ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,479ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,480ms] [Error] [gpu.foundation.plugin] Texture creation failed for the device: 0.
2024-09-24 13:31:22 [110,480ms] [Warning] [omni.syntheticdata.plugin] SdPostRenderVarToHost : invalid input resource for renderVar SemanticOcclusionSD
2024-09-24 13:31:22 [110,480ms] [Error] [omni.syntheticdata.plugin] SdPostRenderVarTextureToBuffer : corrupted input renderVar InstanceSegmentationReductionSD
2024-09-24 13:31:22 [110,482ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,482ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,482ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,482ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,483ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,483ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,483ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,483ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,484ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,484ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,484ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,484ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,487ms] [Warning] [omni.replicator.core.plugin] InstanceSegmentation : missing RenderVar InstanceMapSD
2024-09-24 13:31:22 [110,487ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,487ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,487ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,487ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,488ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,488ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,488ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,488ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,488ms] [Warning] [omni.replicator.core.plugin] SemanticOcclusionReduction : missing RenderVar InstanceMapSD
2024-09-24 13:31:22 [110,488ms] [Warning] [omni.syntheticdata.plugin] SdPostRenderVarTextureToBuffer missing valid input renderVar InstanceSegmentationReductionSD
2024-09-24 13:31:22 [110,488ms] [Warning] [omni.syntheticdata.plugin] SdPostRenderVarToHost missing valid input renderVar SemanticOcclusionSD
2024-09-24 13:31:22 [110,489ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,489ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,489ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,489ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,490ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,490ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,490ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,490ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,494ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,494ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,494ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,494ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,495ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,495ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,495ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,495ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,497ms] [Error] [carb.cudainterop.plugin] dup failed for resourceType: 3 (file descriptor: 954)
2024-09-24 13:31:22 [110,497ms] [Error] [gpu.foundation.plugin] Cannot create cuda external memory for resource!
2024-09-24 13:31:22 [110,497ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,498ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,498ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,498ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,498ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,500ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,500ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,501ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,501ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,501ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,501ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,502ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,502ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,502ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,502ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,503ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,503ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,503ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,503ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,504ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,504ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,504ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,504ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,505ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-09-24 13:31:22 [110,505ms] [Error] [carb.graphics-vulkan.plugin] vkGetMemoryFdKHR failed.
2024-09-24 13:31:22 [110,505ms] [Error] [gpu.foundation.plugin] Cannot create shared handle for resource!
2024-09-24 13:31:22 [110,505ms] [Error] [gpu.foundation.plugin] Buffer creation failed for the device: 0.
2024-09-24 13:31:22 [110,539ms] [Error] [carb.cudainterop.plugin] CUDA error 700: cudaErrorIllegalAddress - an illegal memory access was encountered)
2024-09-24 13:31:22 [110,539ms] [Error] [carb.cudainterop.plugin] Failed to signal external semaphore in CUDA.
2024-09-24 13:31:22 [110,539ms] [Error] [gpu.foundation.plugin] Signal external semaphore failed in CUDA submission in command list "Render graph command list (Render queue 0, device 0, frame submission index 2)"
2024-09-24 13:31:22 [110,564ms] [Error] [carb.cudainterop.plugin] CUDA error 700: cudaErrorIllegalAddress - an illegal memory access was encountered)
2024-09-24 13:31:22 [110,564ms] [Error] [carb.cudainterop.plugin] Failed to wait on external semaphore in CUDA.
2024-09-24 13:31:22 [110,565ms] [Error] [gpu.foundation.plugin] Wait for external semaphore failed in CUDA submission in command list "Render graph command list (Render queue 0, device 0, frame submission index 0)"
2024-09-24 13:31:22 [110,566ms] [Error] [carb.scenerenderer-rtx.plugin] Failed to execute RenderGraph on device 0. Error Code: 1
2024-09-24 13:31:22 [110,566ms] [Warning] [omni.hydra] Rendering failed.
2024-09-24 13:31:22 [110,566ms] [Error] [omni.usd] HydraEngine::render failed to end the compute graph: error code 6
2024-09-24 13:31:22 [111,010ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
2024-09-24 13:31:22 [111,010ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002d742ecd6927d29ebfc974a2ab760b8130c35e5a468ada4ed92feddd9269b
2024-09-24 13:31:22 [111,011ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
2024-09-24 13:31:22 [111,011ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002b541c1cd4b60c9307ba28aa7d3204c9eb5235e0fab0d7c996e414bde1da9
2024-09-24 13:31:22 [111,011ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002903348b4d1029eec446c6590a864a3a008ef22a68e0be50e4e59de312a61
2024-09-24 13:31:22 [111,011ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00021243dc82abc1b3e7c2aae400953dc7b37893e934e528e1f4d148e516d449
2024-09-24 13:31:22 [111,011ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00025e4152f525d16ddcd913970ba7476c55a4afa5a8c4d5ff5223efe9635d40
2024-09-24 13:31:22 [111,011ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002d54822295a901dfcdc7a7fc2d378c0f7da8ac054a20ad9b7a48c0fad0ff8
2024-09-24 13:31:22 [111,011ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002733978048b4d2500ad9fe1902a8a20497f27879687b8ad78d7575e7e87e1
2024-09-24 13:31:22 [111,011ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00022d381ab9f2d028798c5114bd24fa6c28a9f59436b299cfd5966e569047ae
2024-09-24 13:31:22 [111,011ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00024639ea220b98852f00f74cc5271bd7c2aadf895edaca647d587697ef6a58
2024-09-24 13:31:22 [111,042ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
2024-09-24 13:31:22 [111,042ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00021c3d3ccd3d610f2a508e31db3f7cba664d4c2c3eb0468f935c0bfe0f27b3
2024-09-24 13:31:22 [111,042ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00026a3f5696a3cdc183d63d6e49e4b2d5dc1ab8170f117356b007b2f46a13f7
2024-09-24 13:31:22 [111,042ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002a6399a2ff26ecb660dca3b4e3394efb1a9d3793167f791bda3047d6c17b7
2024-09-24 13:31:22 [111,068ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
2024-09-24 13:31:22 [111,068ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00028d3fec46e63e93808db556e67d6a921f9620460bb7f8b7c982ba56f4bb2c
2024-09-24 13:31:22 [111,068ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002a140572bbb67ce8b3167ec027c5fcf5ece2d9ac0e4f9e6a56d25d4360f3f
2024-09-24 13:31:22 [111,068ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00028a3564c3331225a09bda63b27b60be94d2a9e524bdcc2a1a73d813863c27
2024-09-24 13:31:23 [111,511ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
2024-09-24 13:31:23 [111,511ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00020c3dadc06337908898a38e1c77b88b0df8b8dfcc01da80fbbfe992fd740b
2024-09-24 13:31:23 [111,511ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002043cf7bd7e78aa24a96256c43dc504d56cfe6be9e54dd983bf0d81e5ef8d
2024-09-24 13:31:23 [111,512ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00029b2df608d549d105db9e4b5b049bf78d839d427234657632789bf6eb3a65
2024-09-24 13:31:23 [111,512ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002593d1e720db58b44116464aa0f1b03e5350f6f00f1a958d5aeecb328fb5f
2024-09-24 13:31:23 [111,512ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
2024-09-24 13:31:23 [111,512ms] [Error] [omni.physx.cooking.plugin] MeshCookingContext::postbuild: triangulation data request failed.
2024-09-24 13:31:23 [111,512ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002be32812eaa28de7789931ed2be683af3ed218ea265e81a9561b79b00acbf
2024-09-24 13:31:23 [111,512ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00028042a50349ce3735e06fe180d350362d7325767864b29ec36353ae8adb97
2024-09-24 13:31:23 [111,512ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002ee34da2b695736b86440e488363a1f0927841cfb8a01c8e3266cf8304e33
2024-09-24 13:31:23 [111,512ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00029d3b269e0e0cddf144333941f99e732b3c8dab9208b713e8e44e367a729c
2024-09-24 13:31:23 [111,512ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002e93443c9af914d18b4c29f857e5b415d5b589a69eeb35460fabdc2e3ef0a
2024-09-24 13:31:23 [111,542ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
2024-09-24 13:31:23 [111,542ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00021734235441148f2c537ff0f0cf270c4c5f819b3c84eb28aa522e52ed033b
2024-09-24 13:31:23 [111,542ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002f33926c89447e10cec3c746adb6386470c556ecdd870609c5baab544bd3d
2024-09-24 13:31:23 [111,542ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002af367028af0f051c53845ff09b2f0ce885f7c26933c5caa0272c14057a9b
2024-09-24 13:31:23 [111,542ms] [Error] [omni.physx.cooking.plugin] MeshCookingContext::postbuild: triangulation data request failed.
2024-09-24 13:31:23 [111,543ms] [Error] [omni.physx.cooking.plugin] MeshCookingContext::postbuild: triangulation data request failed.
2024-09-24 13:31:23 [111,568ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
2024-09-24 13:31:23 [111,568ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 0002183c6f5a55e640f675fdd8a2cc7efb589bee57afcd1321fcf2db9f7b6edf
2024-09-24 13:31:23 [111,569ms] [Error] [omni.physx.cooking.plugin] MeshCookingContext::postbuild: triangulation data request failed.
2024-09-24 13:31:23 [111,569ms] [Error] [omni.datastore] LocalDataStore : Unable to load block 00022339025541a9b8159a9225cbf93c41e076aaf44ed05186aca588f754a7f9
2024-09-24 13:31:23 [111,569ms] [Warning] [omni.datastore] LocalDataStore : Failed to open data bucket file for read: /home/wojtek/.cache/ov/Kit/106.1/10a4b5c0/PhysXLocalMeshCache/LocalDS0/largecachedata_0
