• Hardware Platform (Jetson / GPU) GPU A4000 & T4 • DeepStream Version DS 6.1 • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
• Issue Type( questions, new requirements, bugs) questions • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Below are our observation with DS 6.1 using nvinferserver plugin as grpc client. With object detection model we are having below observation.
Questions:
If we are using stream_mux batch_size to 16 or 32, we see miss in detection in some source. if we use batch_size 8 then we do not see detection drop on some source. attached video for same.
if we are using sync-input true in same use case we see some detection miss but if we do sync-input false then we do not see detection miss, with file based input we have have observed less frame in output file compare to sync-input true for same source.
We are using our own deep-stream app/gstreamer wrapper based on your project.
Source
Batch
Sync
Avg # Frames
Avg # Empty Frames
Avg # Detections
8
8
Off
1441.75
1.625
2955793.00
8
8
On
1437.5
1.375
2946836.13
8
32
Off
1442
46.5
2846977.88
8
32
On
1437.5
1.375
2947558.88
16
8
Off
1442
1.25
2962775.31
16
8
On
726.25
1.1875
1487887.63
16
32
Off
1442
24
14349.13
Cam2/12 has low # detec, 13862
16
32
On
947.4375
61.8125
1821452.00
Cam1 has very low # detections, 621919
There are multiple issues here. In summary,
Turning sync on causes a frame drop (frame drop level changes based on other factors)
Increased number of sources causes higher level of frame drop when sync is on
Increased batch size and number of sources causes more empty frames i.e. less detection
As long as the number of sources is 8, it performs ok no matter batch size. (sync-inputs is still causing frame drop though)
It seems like there is a limit on number of source a pipeline can have no matter what GPU we use.
T4 and RTX A4000 are quite different in terms of performance yet we get the same result.
We fixed the flickering on the video by turning off sync on filesink. It somehow affects the number of detections and causes flickering. Now, we can have output without flickering on 32 sources with 32 batch size. However, we still see a large number of empty frames (frames with no detection). What is the reason for that?
And why does ‘sync-inputs: 1’ causes frame drop and worse performance?
I have ran the test with deepstream-test3 app with some changes to support visualisation of the output using RTSP. I see some detection drop of multiple sources.
attached video and app source code for same with performance number.
“sync-inputs” will drop frames which reached later than the 1/FPS to sync all input sources according to the timestamp.
