ealali
February 3, 2021, 9:30am
1
Hi
We use nvvidconv element to convert from YUY2 to I420 format
Each channel resolution is 1920x1080 (Full HD)
It works fine when we use one or two channels BUT when we use 4 channels we get big latency
What can cause such problem?
What can cause this problem?
We enable dynamic frequency scaling to hardware converter(VIC) in latest releases. Please check the steps in
Please excute the steps to run VIC in max clock and try again:
Disable runtime suspend of VIC
$ echo on > /sys/devices/13e10000.host1x/15340000.vic/power/control
Set userspace governor
$ echo userspace > /sys/devices/13e10000.host1x/15340000.vic/devfreq/15340000.vic/governor
Set max_freq
$ cat /sys/devices/13e10000.host1x/15340000.vic/devfreq/15340000.vic/available_frequencies
$ echo [max_freq_val] > /sys/devices/13e10000.host1x/15340000.vic/devfreq/15340000.vic/max_freq
Set targ…
And run the engine in max clock and try again.
ealali
February 11, 2021, 6:41am
4
Hi
We are using L4T version 28.2.1
Can you tell me how to control VIC using this version of L4T?
DaneLLL
February 17, 2021, 6:27am
6
If you run like
v4l2src ! video/x-raw,format=YUY2,width=1920,height=1080 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=I420' ! ...
In nvvidconv plugin, it copies YUY2 data from CPU buffers to NVMM buffers and convert YUY2 to I420 NVMM buffers. In multi channels, copying CPU buffers to NVMM buffers may be the bottleneck. You need to execute sudo nvpmodel -m 0 and sudo jetson_clocks , to get max CPU clocks.
VIC engine is at max clock on r28 release. DFS is applied on r32 releases.
