Xavier AGX
jetpack 4.3
Deepstream 4
Model - yolov3tiny
What does **PERF actually report? Is it just the incoming fps of the incoming stream prior to any processing?
I am streaming 8 sources via rtsp at 24 fps
I have a tee output.log which shows all sources running at 24fps but there is a delay even when there are no detections on any source
I want to find the maximum possible fps I can set which doesn’t cause a delay
How do I calculate processing time?
thanks
