Could you please review the wall mesh in the image?
Error: Edits in the file are saved with an “instance” mark. Issue: Deleting the object with the instance mark also removes the edits made to the base file. Goal: I want to retain the edits in the base file while removing the instance mark only.
Would you be able to identify the cause and provide a solution? Thank you!
I am not really sure what you are asking. I am trying to understand your workflow. If you delete an instance it should not affect the master object. But it depends on how you did you edits.
Are you trying to build geometry inside of Composer? That is very difficult to do. I would build all your geometry outside of composer. We are not a modelling software.
