CUDA don’t work on a Dell Latitude D830 with NVS 140M graphics card.
The system is Fedora 8 with Nvidia driver 169.04 from Livna
$ PATH=$PATH:/opt/cuda/bin LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/cuda/lib ./deviceQuery
There is no device supporting CUDA.
Device 0: "Device Emulation (CPU)"
Major revision number: -1
Minor revision number: -1
Total amount of global memory: -1 bytes
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1350000 kilohertz
Test PASSED
NVS 140M is normally supported by CUDA 1.1, then, what should I do to have my graphics card able to work with CUDA?
