What is happening
I’ve been having an issue with my Quadro RTX 5000 Max-Q on a Dell Precision 7550 where, after playing a game for a while, the GPU suddenly enters a severe low-clock state.
nvidia-smi shows the GPU dropping to around 600 MHz core / 405 MHz memory while still being at roughly 90–95% utilization. The game’s performance then becomes extremely poor.
A reboot immediately fixes the problem.
This has happened across multiple NVIDIA driver versions, so it doesn’t seem to be specific to the current 610 driver.
System
- Dell Precision 7550
- Quadro RTX 5000 with Max-Q Design, 16 GB
- BIOS 1.44.0
- CachyOS Linux
- Kernel 7.1.8-1-cachyos
- NVIDIA driver 610.57.04
- KDE Plasma / X11 (Happens on wayland aswell) / KWin
- Connected to AC power when the issue occurs
- Battery is full
Normal vs. broken state
Immediately after reboot, the GPU behaves normally. For example:
Temperature: ~50 C
Power: ~41 W
Core clock: 1110 MHz
Memory clock: 5000 MHz
P-state: P3
When the problem occurs:
Temperature: 56 C
Power: ~20–24 W
Core clock: 600 MHz
Memory clock: 405 MHz
P-state: P8
GPU utilization: ~90–95%
The GPU’s power limit remains 80 W:
Current Power Limit: 80 W
Requested Power Limit: 80 W
Default Power Limit: 80 W
The interesting part is that nvidia-smi -q -d PERFORMANCE shows:
SW Power Cap: Not Active
HW Thermal Slowdown: Not Active
SW Thermal Slowdown: Not Active
but the HW Power Braking counter becomes non-zero. For example:
HW Power Braking : 39187117 us
The GPU is only at ~56 C and ~20–24 W when this happens, so this doesn’t appear to be normal thermal throttling or the GPU reaching its 80 W power limit.
Reproduction
It seems to happen during sustained gaming.
For example, I’ve been able to reproduce it with SimRail running through Steam/Proton:
- Boot normally.
- Connect AC power.
- Start the game.
- Play for a while.
- The GPU suddenly drops to the low-clock state.
nvidia-smishows around 600/405 MHz and P8.- Rebooting the laptop restores normal GPU performance.
I’ve also experienced the issue with earlier NVIDIA driver versions, so it doesn’t appear to be a regression exclusive to 610.57.04.
What I’m wondering
Could this be related to the Dell platform/EC asserting the GPU’s hardware power-brake signal?
I’m particularly interested in whether this is something the NVIDIA driver can handle differently, or whether there is a known issue with the Precision 7550’s power-management/firmware interaction with the RTX 5000 Max-Q.
nvidia-bug-report.log.gz (549.2 KB)
I’m happy to provide any additional logs or run specific tests if they would help track this down.
