GPU - RTX2060 with Docker
• DeepStream Version
5.1
n/a
• TensorRT Version
7.2.3-1+cuda11.1
455.32.00
question
I would like to create a pipeline using nvdewarper:
gst-launch-1.0 --gst-debug=3 \
filesrc location=/data/FISHEYE_cut.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvvideoconvert ! nvdewarper config-file=/data/config_dewarper.txt nvbuf-memory-type=3 ! mux.sink_0 \
nvstreammux name=mux batch-size=2 num-surfaces-per-frame=2 width=1920 height=1080 ! nvstreamdemux name=demux \
demux.src_0 ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=/data/output_0.mp4 \
demux.src_1 ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=/data/output_1.mp4
But the pipeline fails to run with core dump:
Redistribute latency…
0:00:00.673620131 642 0x559fe907fc50 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2h264enc1:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:00.682295752 642 0x559fe907fc50 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2h264enc0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:00.682759482 642 0x559fe907fc50 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:00.682789497 642 0x559fe907fc50 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:00.707336912 642 0x7efe744e8a30 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:00.814979219 642 0x7efe740230a0 ERROR nvvideoconvert gstnvvideoconvert.c:3387:gst_nvvideoconvert_transform: buffer transform failed
0:00:00.815424763 642 0x7efe740230a0 ERROR nvvideoconvert gstnvvideoconvert.c:3387:gst_nvvideoconvert_transform: buffer transform failed
0:00:00.816408151 642 0x7efe740230a0 ERROR nvvideoconvert gstnvvideoconvert.c:3387:gst_nvvideoconvert_transform: buffer transform failed
0:00:00.816441894 642 0x559fe907fc50 WARN qtdemux qtdemux.c:6073:gst_qtdemux_loop: error: Internal data stream error.
0:00:00.816482802 642 0x559fe907fc50 WARN qtdemux qtdemux.c:6073:gst_qtdemux_loop: error: streaming stopped, reason error (-5)
0:00:00.816955769 642 0x7efe740230a0 FIXME basesink gstbasesink.c:3145:gst_base_sink_default_event: stream-start event without group-id. Consider implementing group-id handling in the upstream elements
ERROR: from element /GstPipeline:pipeline0/GstQTDemux:qtdemux0: Internal data stream error.
Additional debug info:
qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline0/GstQTDemux:qtdemux0:
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to NULL …
free(): invalid next size (fast)
Aborted (core dumped)
When using a single dewarped surface num-surfaces-per-frame=1 the output is properly generated.
filesrc location=/data/FISHEYE_cut.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! nvvideoconvert ! nvdewarper config-file=/data/config_dewarper1.txt nvbuf-memory-type=3 ! mux.sink_0 \
nvstreammux name=mux batch-size=2 num-surfaces-per-frame=1 width=1920 height=1080 ! nvstreamdemux name=demux \
demux.src_0 ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=/data/output_single.mp4
The file /data/config_dewarper.txt has the following content:
[property]
output-width=4096
output-height=1300
num-batch-buffers=2[surface0]
projection-type=1
surface-index=0
width=1024
height=512
top-angle=15
bottom-angle=-60
pitch=90
yaw=0
roll=-110
focal-length=512
src-fov=180[surface1]
projection-type=1
surface-index=1
width=1024
height=512
top-angle=15
bottom-angle=-60
pitch=90
yaw=0
roll=-110
focal-length=512
src-fov=180
and /data/config_dewarper1.txt has one of the surfaces removed and num-batch-buffers=1
Any clues on how to make this work? Thanks!
