I’m trying to modify the pipeline from test4 into something like:
[i]multiple input uri → nvstreammux → … → tee → queue1 → nvstreamdemux → sink_bin[n] {queue → transform/videoconv → capfilter → … → rtspoutput}
/////////////////////////////////////////////////////////tee (another branch) → queue2 → msgconv → … [/i]
But I failed to link demux to sink_bin. Below is how I did this part, and I wonder what’s wrong.
Thanks in advance.
# include "deepstream_common.h"
# include "deepstream_config.h"
# include <gst/rtsp-server/rtsp-server.h>
//Basically same as create_udpsink_bin in "deepstream_sink_bin.c"
static GstElement * create_sink_bin (guint index)
GstElement *bin = NULL;
gchar elem_name[50];
gchar encode_name[50];
gchar rtppay_name[50];
gchar bin_name[16] = { };
g_snprintf (bin_name, 15, "sink-bin-%02d", index);
bin = gst_bin_new (bin_name);
GstElement *queue = NULL, *cap_filter = NULL, *transform = NULL, *encoder = NULL,
*rtppay = NULL, *codecparse = NULL, *sink = NULL;
GstCaps *caps = NULL;
g_snprintf (elem_name, sizeof (elem_name), "sink-bin-%02d-queue", index);
queue = gst_element_factory_make (NVDS_ELEM_QUEUE, elem_name);
g_snprintf (elem_name, sizeof (elem_name), "sink-bin-%02d-transform", index);
transform = gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, elem_name);
g_snprintf (elem_name, sizeof (elem_name), "sink-bin-%02d-capfilter", index);
cap_filter = gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, elem_name);
caps = gst_caps_from_string("video/x-raw(memory:NVMM), format=I420");
g_object_set(G_OBJECT(cap_filter), "caps", caps, NULL);
g_snprintf (encode_name, sizeof (encode_name), "sink-bin-%02d-encoder", index);
g_snprintf (rtppay_name, sizeof (rtppay_name), "sink-bin-%02d-rtppay", index);
codecparse = gst_element_factory_make("h264parse", "h264-parser");
encoder = gst_element_factory_make(NVDS_ELEM_ENC_H264, "rtsp-encoder");
rtppay = gst_element_factory_make("rtph264pay","rtsp-pay");
g_object_set(G_OBJECT(encoder),"bitrate", rtspbitrate, NULL);
g_object_set(G_OBJECT(encoder),"iframeinterval", rtspiframeitv, NULL);
g_object_set(G_OBJECT(encoder),"gpu-id",rtspenc_gpuid, NULL);
g_object_set(G_OBJECT(transform),"gpu-id",rtsptrans_gpuid, NULL);
g_snprintf (elem_name, sizeof (elem_name), "sink-bin-%02d-udpsink", index);
sink = gst_element_factory_make ("udpsink", elem_name);
g_object_set(G_OBJECT(sink), "host", rtsphost, "port", rtspport, "async", FALSE, "sync", rtspsync, NULL);
gst_bin_add_many(GST_BIN(bin),queue,cap_filter,transform,encoder,codecparse,rtppay,sink,NULL);
NVGSTDS_LINK_ELEMENT (queue, transform);
NVGSTDS_LINK_ELEMENT (transform, cap_filter);
NVGSTDS_LINK_ELEMENT (cap_filter, encoder);
NVGSTDS_LINK_ELEMENT (encoder, rtppay);
NVGSTDS_LINK_ELEMENT (rtppay, sink);
NVGSTDS_BIN_ADD_GHOST_PAD (bin, queue, "sink");
start_rtsp_streaming(rtspport, udpport, NV_DS_ENCODER_H264);
return bin;
GstElement *demux = gst_element_factory_make(NVDS_ELEM_STREAM_DEMUX, "demuxer");
//Only create and output src_01
GstElement *sink_bin = create_sink_bin(1);
//Function in "deepstream_common.h", which returns error msg "Failed to link 'demuxer' and 'sink-bin-01'"
link_element_to_demux_src_pad(demux,sink_bin,1);
