**• Hardware Platform (Jetson / GPU)**T4
• DeepStream Version5
• TensorRT Version7.0.0.11
**• NVIDIA GPU Driver Version (valid for GPU only)**440+
demuxer in_system_timestamp plugin comes when I turn of Tiled display. Can you give the reason?
When I turn it on it does not come. Kindly give reason
Can you give all information of reproducing this error?
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=7
columns=5
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
num-sources=1
#uri=file://Videos_for_Usecase_1/UseCase1-1.mp4
uri=file://Videos_for_Usecase_1/UseCase1-2.mp4
intra-decode-enable=0
gpu-id=0
cudadec-memtype=0
[streammux]
gpu-id=0
batch-size=1
batched-push-timeout=40000
Set muxer output width and height
width=1920
height=1080
nvbuf-memory-type=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=1
sync=0
source-id=0
gpu-id=0
[osd]
enable=0
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=1
gie-unique-id=1
interval=0
labelfile-path=ssd_coco_labels.txt
model-engine-file=sample_ssd_relu6.uff_b1_gpu0_int8.engine
config-file=config_infer_primary_ssd.txt
nvbuf-memory-type=0
[secondary-gie1]
enable=1
model-engine-file=any_model.engine
batch-size=1
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=2;
config-file=config_infer_reid.txt
Its not actually an error . As you can see Comp name=demuxer in_system_timestamp comes only when I do not enable Tiled display.
I want to know what the reason is
Please refer to deepstream-app source codes, when nvmultistreamtiler is disabled, the nvstreamdemux will be enabled, so you will see the log for nvstreamdemux. When nvmultistreamtiler is enabled, there is no nvstreamdemux in the pipeline, so there is no related log.
This is deepstream-app sample implementation.
