FYI, some of those releases can do OTA to the next release. Do you have a local Jetson with the older R32.3.1 release which is not critical and you could test having it run an OTA upgrade to a more recent release? I couldn’t say for certain, but during such an upgrade some of those patches are probably installed (if it works…thus the suggestion to test on a non-critical Jetson).
Our product is using a custom Linux distribution based on Yocto more specifically meta-tegra as the BSP layer . We can not perform APT updates because this is not allowed. we have our own to apply updates.
We need the patches (only for trusty because we have the sources)
and the new bootloader binaries which correspond to the L4T R32.3.1 release.
sorry, our current policy is NOT back porting the fixes.
due to we’re based-on the latest code-line to submit the changes; there’re code conflicts and also dependency for back port the changes to those earlier releases.
