Dependency error while Installing jetson software with NVIDIA SDK Manager
I tried to flash my Jetson Nano B01 with SDK manager while my board was stuck at the continue booting screen with SD card image method. when i run SDK manager it shows error messages at the Target component sections (please refer to the image attached). I have tried with Repair/Uninstall method which is mentioned in the official website for SDK Manager but unfortunately, it did not fix the issue. Could you please guide me with this to resolve this issue?
File System and OS Install error
08:55:54 ERROR: File System and OS - target_image: chroot: failed to run command ‘dpkg’: Exec format error
08:55:54 ERROR: File System and OS - target_image: [exec_command]: /bin/bash -c /home/shakthi/.nvsdkm/replays/scripts/JetPack_4.6.5_Linux/NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP.sh; [error]: chroot: failed to run command ‘dpkg’: Exec format error
08:55:54 INFO: File System and OS - target_image: [host] [ 895.57 MB used. Disk Avail on Partition /dev/sdc: 940.54 GB ]
08:55:54 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_T210_COMP Install took 52m24s ]
08:55:54 ERROR: File System and OS - target_image: command terminated with error
08:55:54 SUMMARY: File System and OS - target_image: First Error: Installation failed.
** Dependency error**
Dependency error shows in CUDA Toolkit for L4T, cuNN on Target, DeepStream , Drivers for Jestion, Flash jetson nano, and in Multimedia API
This all shows the same error message which written in the below
08:02:58 INFO: cuDNN on Target - target: Found file /home/shakthi/Downloads/nvidia/sdkm_downloads/libcudnn8-dev_8.2.1.32-1+cuda10.2_arm64.deb with correct checksum, skip downloading.
08:55:54 SUMMARY: cuDNN on Target - target: Depends on failed component
Could you please guide me with this?
Hi fst19021,
It seems the issue from your host.
Are you using VM/Docker for SDK Manager on Windows PC rather than using standalone Ubuntu host PC?
Yes, I am using VM for run sdk manager
