Dependency problem how to solve the problem that i am facing with these type of dependeny
Recently i am facing a situation well i would like to explain it with an example which goes below
int previous_pixel;
fs=get_global_id(0);
us=fs%frame_width;
if(us==0)
previous_pixel=0;
if(input_buffer[fs]==12)
previous_pixel=fs;
else if(previous_pixel!=0)
//operation being done
calculate some value h here than,
previous_pixel=h;
well this is my condition i how can i solve this dependency problem for previous_pixel. Its taking the value zero for all threads.
Thanks in advance
Best regards
Megharaj
Can you post a bit more about the dimensions you are using ?
What is frame_width, What is the workgroup size and so on.
Thanks a lot for your replay.
I got the solution for that , I am running one row in one thread because dependency was there only inside a row, each row were independent of other so got the solution as shown below.
Initially I was doing like this
Global_worksize=(width*height)
__kernel(…)
Id=get_global_id(0);
//operation
Now
Global_worksize=(height)//taking only height number of threads
__kernel(…)
For(i=0;i<width;i++)
//operation
}//end of for loop
Now the problem is solved but
Disadvantage :
Number of parallel threads have been reduced.
Best regards
Megharaj.
