**• Hardware Platform (Jetson / GPU) AGX
**• DeepStream Version 5.0
**• JetPack Version (valid for Jetson only) 4.4
**• TensorRT Version 7.1
**• NVIDIA GPU Driver Version (valid for GPU only) 10.2
**• Issue Type questions
I have implemented the EfficientNet-b0 classification network using the tensorRT C++ API, and the single image result is consistent with the Python result. However, when deploying the EfficientNet-b0 classification network to deepstream, it encountered a situation that did not match the calculation result of the Python. I think it may be inconsistent with Python image preprocessing in deepstream.
The primary-gie is yolov5
[primary-gie]
enable=1
gpu-id=0
model-engine-file=yolov5s_bn4.engine
labelfile-path=labels.txt
#batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV5.txt
config_infer_primary_yoloV5.txt:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#0=RGB, 1=BGR
model-color-format=0
process-mode=1
network-mode=2
num-detected-classes=80
gie-unique-id=1
network-type=0
#is-classifier=0
output-blob-names=prob
#cluster-mode=2
maintain-aspect-ratio=1
parse-bbox-func-name=NvDsInferParseCustomYoloV5
custom-lib-path=nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
#scaling-filter=0
#scaling-compute-hw=0
#force-implicit-batch-dim=1
[class-attrs-all]
nms-iou-threshold=0.5
pre-cluster-threshold=0.4
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
The secondary-gie2 is efficientnet-b0
[secondary-gie2]
enable=1
#model-engine-file=efficientnet-b0_3_channel_misheng.engine
model-engine-file=efficientnet-b0_single_channel_misheng_bn8.engine
batch-size=8
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_secondary_efficientnet_b0_bn8.txt
[property]
gpu-id=0
net-scale-factor=0.0175
offsets=116.28
labelfile-path=efficientnet_b0_labels.txt
#input-dims=3;224;224;0
infer-dims=1;224;224
#uff-input-blob-name=input_1
batch-size=8
process-mode=2
model-color-format=2
network-mode=0
network-type=1
num-detected-classes=3
interval=0
gie-unique-id=1
classifier-threshold=0.1
maintain-aspect-ratio=0
#network-mode=1
#is-classifier=1
classifier-async-mode=1
#classifier-threshold=0.51
input-object-min-width=2
input-object-min-height=2
In secondary-gie2, image is gray. This is my preprocessing method using C++.
for (int i = 0; i < global_params.input_h * global_params.input_w; i++) {
data[i] = ((float)img.at<cv::Vec3b>(i)[0] - 116.28) * 0.0175;
