I am trying to provide docker images for deployment of a set of custom packages that depend on the Isaac ROS packages - isaac_ros_common, isaac_ros_tensor_rt etc.
I would like to provide the docker image with all ros packages compiled.
Initially I tried something similar to how other packages are built in Dockerfile.ros2_humble such as nav2
# Copy CUDA libraries
COPY test/lib/libcusolver.so.11 /usr/local/cuda-11.4/targets/aarch64-linux/lib/libcusolver.so.11
COPY test/lib/libcusparse.so.11 /usr/local/cuda-11.4/targets/aarch64-linux/lib/libcusparse.so.11
COPY test/lib/libcurand.so.10 /usr/local/cuda-11.4/targets/aarch64-linux/lib/libcurand.so.10
COPY test/lib/libnvToolsExt.so /usr/local/cuda-11.4/targets/aarch64-linux/lib/libnvToolsExt.so
COPY test/lib/libcupti.so.11.4 /usr/local/cuda-11.4/targets/aarch64-linux/lib/libcupti.so.11.4
COPY test/lib/libcudla.so.1 /usr/local/cuda-11.4/targets/aarch64-linux/lib/libcudla.so.1
COPY test/include/nvToolsExt.h /usr/local/cuda-11.4/targets/aarch64-linux/include/nvToolsExt.h
COPY jetson_multimedia_api /usr/src/jetson_multimedia_api
# COPY aarch64-linux-gnu /opt/nvidia/vpi2/lib/aarch64-linux-gnu
# Install isaac-ros packages
RUN apt-get update && mkdir -p ${ROS_ROOT}/src && cd ${ROS_ROOT}/src \
&& git clone https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_common.git && cd isaac_ros_common && git checkout 94dfe8dcc64a2cd3e8f1d50cf05de1e1ab1e9c8b \
&& git lfs fetch && git lfs checkout && cd .. \
&& git clone https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_image_pipeline.git && cd isaac_ros_image_pipeline && git checkout 6e498440163f65596e6cc58b37b6cef50336afec \
&& git clone https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_nitros.git && cd isaac_ros_nitros && git checkout 2d35cacf6b57abbb37ea8ae769d8661b1970c8e7 \
&& source ${ROS_ROOT}/setup.bash && cd ${ROS_ROOT} \
&& rosdep install -y -r --ignore-src --from-paths src --rosdistro ${ROS_DISTRO} \
&& colcon build --merge-install --cmake-args -DCMAKE_BUILD_TYPE=RelWithDebInfo --packages-up-to-regex isaac_ros* --packages-ignore isaac_ros_to_h264_msgs_packet isaac_ros_stereo_image_proc isaac_ros_triton \
&& rm -Rf src build log \
&& rm -rf /var/lib/apt/lists/* \
&& apt-get clean
However this required DOCKER_BUILDKIT=0 when building, and when running the packages it doesn’t work anyway…
Is there any valid method to providing a prebuilt isaac ros environment with a docker image?
