Deploying AWS Lambda function on Jetson Nano using Greengrass
I am trying to deploy a Lambda function on the Jetson Nano. I have followed modules 1-3 in the AWS Developer guide (link below).
https://docs.aws.amazon.com/greengrass/v1/developerguide/gg-gs.html
At Step 3 of Module 3 part 1, " Verify the Lambda function is running on the core device", I am not able to receive the MQTT messages from the ‘hello/world’ topic
Greengrass is successfully started on my Jetson Nano. Could I get some help with this?
Hi
Would you mind checking with the AWS team if they support the Jetson environment first?
