Hardware - GPU (A100/A30/T4/V100) Quadro RTX 8000
Hardware - CPU Intel(R) Xeon(R) Gold 5218R CPU @ 2.10GHz
Operating System - Ubuntu 18.04.5 LTS
Riva Version - 1.9 beta
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
Hi all, I have been following the Quick Start Guide to deploy my custom trained citrinet and quartznet model.
I have also specified the model used in my js client using the GRPC model parameter riva_asr.proto
Upon running my node js client, it seems that the ASRService.StreamingRecognize is called, but no model is selected for reference and no transcription is happening.
However, when i change the model parameter back the ‘riva-asr’ model, the client works as usual and I am able to successfully transcribe the audio file
Here is my docker logs and excerpt of my nodejs client for reference :
dockerlogs.txt (35.1 KB)
let config = new rivaMessages.RecognitionConfig()
config.setEncoding(rivaAudioMessages.AudioEncoding.LINEAR_PCM);
// Need to set sample rate hertz according to the sample rate of the audio file
config.setSampleRateHertz(48000);
config.setMaxAlternatives(1);
config.setLanguageCode(‘en-US’);
config.setModel(‘name_of_model’);
let streamingConfig = new rivaMessages.StreamingRecognitionConfig();
streamingConfig.setConfig(config);
streamingConfig.setInterimResults(true);
let streamingRequest = new rivaMessages.StreamingRecognizeRequest();
streamingRequest.setStreamingConfig(streamingConfig);
